Up to 20% off select tools
Nokia 6236i Front Casing Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
84
All Time:
2,484
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Introduction
Go to step 1 ↓
This guide will give step-by-step instructions for removing the Nokia 6236i front casing without damage. This action may be considered if the front case is cracked, needs in-depth cleaning, or keyboard buttons need replacement.
    1. Nokia 6236i Front Casing Replacement, Battery: step 1, image 1 of 2 Nokia 6236i Front Casing Replacement, Battery: step 1, image 2 of 2
      • Using your thumb, apply pressure to the battery casing (below the camera). Firmly pull towards the bottom of the phone.
      • Lift the battery case off of the phone.
      Ask FixBot
    2. Nokia 6236i Front Casing Replacement: step 2, image 1 of 3 Nokia 6236i Front Casing Replacement: step 2, image 2 of 3 Nokia 6236i Front Casing Replacement: step 2, image 3 of 3
      • Use your thumb to get underneath the battery and pull up and out from the bottom of the battery tray.
      • The battery should lift out with minimal resistance.
      Ask FixBot
    1. Nokia 6236i Front Casing Replacement, SIM Card: step 3, image 1 of 3 Nokia 6236i Front Casing Replacement, SIM Card: step 3, image 2 of 3 Nokia 6236i Front Casing Replacement, SIM Card: step 3, image 3 of 3
      • Once the battery is removed, pull the tab of the metal sim card cover, and lift it up.
      • The sim card is underneath and can now be removed.
      Ask FixBot
    1. Nokia 6236i Front Casing Replacement, Front Casing: step 4, image 1 of 3 Nokia 6236i Front Casing Replacement, Front Casing: step 4, image 2 of 3 Nokia 6236i Front Casing Replacement, Front Casing: step 4, image 3 of 3
      • Insert a spudger into the indention on the bottom right side of the device.
      • Slide the spudger upward to a second indention at the top of the phone.
      • The front casing will detach from the phone.
      Ask FixBot
The front casing will be detached without causing damage to the case or phone model.
For reassembly, complete the listed steps in reverse.
Author
with
Erik Lindahl
63 Reputation
4 Guides authored
Cal Poly, Team 10-46, Garner Spring 2010 Member of Cal Poly, Team 10-46, Garner Spring 2010
CPSU-GARNER-S10S10G46
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 84
All Time: 2,484
