Nokia 6133 Speaker Replacement
  1. Nokia 6133 Speaker Replacement, Battery: step 1, image 1 of 2 Nokia 6133 Speaker Replacement, Battery: step 1, image 2 of 2
    • Remove the back cover of your cell phone by applying slight pressure with your thumb and pushing up towards the top of the phone.
    • Lift off back cover.
    Ask FixBot
  2. Nokia 6133 Speaker Replacement: step 2, image 1 of 3 Nokia 6133 Speaker Replacement: step 2, image 2 of 3 Nokia 6133 Speaker Replacement: step 2, image 3 of 3
    • Use your index finger to first push down and then lift up the battery as shown.
    • Remove battery from cell phone.
    Ask FixBot
  3. Nokia 6133 Speaker Replacement, Keypad: step 3, image 1 of 2 Nokia 6133 Speaker Replacement, Keypad: step 3, image 2 of 2
    • Unscrew two T5 torx screws easily visible on the back side of the cell phone
    • Screws: 7.8mm
    • Once screw are removed, the phone will separate easily into two pieces connected by a flexible wire strip.
    • Be sure to not lose or disconnect the indicated piece that the screw mounts to. It is spring loaded and is very dificult to reattach.
    Ask FixBot
  4. Nokia 6133 Speaker Replacement: step 4, image 1 of 3 Nokia 6133 Speaker Replacement: step 4, image 2 of 3 Nokia 6133 Speaker Replacement: step 4, image 3 of 3
    • Use an iPod opening tool to gently pry open the back case as indicated in the picture.
    • Work your way down the side of the phone starting from the top down to the bottom. (Use multiple prying tools if necessary)
    • REPEAT on both sides, and be careful not to stab the circuitry with the tools.
    Ask FixBot
  5. Nokia 6133 Speaker Replacement: step 5, image 1 of 3 Nokia 6133 Speaker Replacement: step 5, image 2 of 3 Nokia 6133 Speaker Replacement: step 5, image 3 of 3
    • Gently pull the phone apart and the flexible wire should detach from its connection as shown.
    • If not, lift up on the black tab within the left box in the picture.
    • With the front half of the phone, push the keypad towards the removed portion of the phone.
    • To clean, use a damp cloth with water.
    Ask FixBot
  6. Nokia 6133 Speaker Replacement, Logic Board: step 6, image 1 of 1
    • Use a T6 Torx Screwdriver to remove the screw located in the bottom right corner of the back panel.
    • Screw: 6.4 mm
    Ask FixBot
  7. Nokia 6133 Speaker Replacement: step 7, image 1 of 2 Nokia 6133 Speaker Replacement: step 7, image 2 of 2
    • Lift up from the top of the logic board as shown to remove.
    Ask FixBot
  8. Nokia 6133 Speaker Replacement, Speaker: step 8, image 1 of 2 Nokia 6133 Speaker Replacement, Speaker: step 8, image 2 of 2
    • After removing the logic board from the back of the phone, pry the speaker out from the bottom with an iPod opening tool.
    • It should pop out easily
    Ask FixBot
Vincent Benvin
121 Reputation
4 Guides authored
Cal Poly, Team 23-82, Johann Spring 2010 Member of Cal Poly, Team 23-82, Johann Spring 2010
CPSU-JOHANN-S10S23G82
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 35
All Time: 3,098
