Nokia 6133 External/Main LCD Replacement
    1. Nokia 6133 External/Main LCD Replacement, Battery: step 1, image 1 of 2 Nokia 6133 External/Main LCD Replacement, Battery: step 1, image 2 of 2
      • Remove the back cover of your cell phone by applying slight pressure with your thumb and pushing up towards the top of the phone.
      • Lift off back cover.
      Ask FixBot
    2. Nokia 6133 External/Main LCD Replacement: step 2, image 1 of 3 Nokia 6133 External/Main LCD Replacement: step 2, image 2 of 3 Nokia 6133 External/Main LCD Replacement: step 2, image 3 of 3
      • Use your index finger to first push down and then lift up the battery as shown.
      • Remove battery from cell phone.
      Ask FixBot
    1. Nokia 6133 External/Main LCD Replacement, Keypad: step 3, image 1 of 2 Nokia 6133 External/Main LCD Replacement, Keypad: step 3, image 2 of 2
      • Unscrew two T5 torx screws easily visible on the back side of the cell phone
      • Screws: 7.8mm
      • Once screw are removed, the phone will separate easily into two pieces connected by a flexible wire strip.
      • Be sure to not lose or disconnect the indicated piece that the screw mounts to. It is spring loaded and is very dificult to reattach.
      Ask FixBot
    2. Nokia 6133 External/Main LCD Replacement: step 4, image 1 of 3 Nokia 6133 External/Main LCD Replacement: step 4, image 2 of 3 Nokia 6133 External/Main LCD Replacement: step 4, image 3 of 3
      • Use an iPod opening tool to gently pry open the back case as indicated in the picture.
      • Work your way down the side of the phone starting from the top down to the bottom. (Use multiple prying tools if necessary)
      • REPEAT on both sides, and be careful not to stab the circuitry with the tools.
      Ask FixBot
    3. Nokia 6133 External/Main LCD Replacement: step 5, image 1 of 3 Nokia 6133 External/Main LCD Replacement: step 5, image 2 of 3 Nokia 6133 External/Main LCD Replacement: step 5, image 3 of 3
      • Gently pull the phone apart and the flexible wire should detach from its connection as shown.
      • If not, lift up on the black tab within the left box in the picture.
      • With the front half of the phone, push the keypad towards the removed portion of the phone.
      • To clean, use a damp cloth with water.
      Ask FixBot
    1. Nokia 6133 External/Main LCD Replacement, External/Main LCD: step 6, image 1 of 2 Nokia 6133 External/Main LCD Replacement, External/Main LCD: step 6, image 2 of 2
      • Using an iPod opening tool, pry open the case that houses the LCD screens by inserting it at the bottom as shown.
      • VERY FRAGILE!! Don't press hard on either side of the LED.
      • Run the tool all along the edge between the darker front case and silver back.
      • Rather difficult to open this part, be careful not to compromise the screens.
      Ask FixBot
    2. Nokia 6133 External/Main LCD Replacement: step 7, image 1 of 2 Nokia 6133 External/Main LCD Replacement: step 7, image 2 of 2
      • Remove the first flex-wire connection by inserting your thumbnail directly underneath the connection as shown. Will pry off easily.
      • This flex-wire connects the LCD logic board to the main logic board removed earlier.
      • Remove the two other flex-wire connections at the top and bottom of the LCD logic board. Pry up on the respective connections as shown.
      • Square LCD logic board will detach now.
      Ask FixBot
    3. Nokia 6133 External/Main LCD Replacement: step 8, image 1 of 3 Nokia 6133 External/Main LCD Replacement: step 8, image 2 of 3 Nokia 6133 External/Main LCD Replacement: step 8, image 3 of 3
      • Pry back the associated tabs using your thumbnail or an iPod opening tool by pulling them away from the LCD panel.
      • LCD can now be removed easily.
      • To clean use any multipurpose lens cleaner and a soft cloth. DO NOT get lens cleaner on any electronic component!
      • Shown:
      • LCD (Main display side)
      • LCD logic board
      • Case that holds above components and camera.
      Ask FixBot
Will
40 Reputation
1 Guide authored
Cal Poly, Team 23-82, Johann Spring 2010 Member of Cal Poly, Team 23-82, Johann Spring 2010
CPSU-JOHANN-S10S23G82
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 31
All Time: 5,000
