Up to 20% off select tools
Nokia 6086 Screen Replacement
Views: 4.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
81
All Time:
4,171
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Replacing a damaged screen.
    1. Nokia 6086 Screen Replacement, Battery: step 1, image 1 of 1
      • Turn off the phone.
      • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
      • Position the phone so that the back side is in view.
      Ask FixBot
    2. Nokia 6086 Screen Replacement: step 2, image 1 of 3 Nokia 6086 Screen Replacement: step 2, image 2 of 3 Nokia 6086 Screen Replacement: step 2, image 3 of 3
      • Remove the back battery cover.
      • Apply pressure on the cover while simultaneously sliding the cover downward.
      Ask FixBot
    3. Nokia 6086 Screen Replacement: step 3, image 1 of 3 Nokia 6086 Screen Replacement: step 3, image 2 of 3 Nokia 6086 Screen Replacement: step 3, image 3 of 3
      • Insert the iPod opening tool between the base of the phone and the phone battery.
      • Position the phone so that the battery won't fall out of the phone.
      • The battery lifts out of the phone fast and easily.
      • Carefully lift the battery out of the phone.
      Ask FixBot
    1. Nokia 6086 Screen Replacement, Top Front Cover: step 4, image 1 of 1
      • Close the phone.
      • Face the front cover forward.
      Ask FixBot
    2. Nokia 6086 Screen Replacement: step 5, image 1 of 2 Nokia 6086 Screen Replacement: step 5, image 2 of 2
      • Locate the 4.5 mm notch at the top of the phone.
      • Place the iPod opening tool into the opening.
      • Slightly prop up the top section by lifting the tool.
      Ask FixBot
    3. Nokia 6086 Screen Replacement: step 6, image 1 of 3 Nokia 6086 Screen Replacement: step 6, image 2 of 3 Nokia 6086 Screen Replacement: step 6, image 3 of 3
      • Wedge the iPod opening tool between the top cover and the phone.
      • Gently lift the top cover away from the phone using the iPod opening tool.
      • This unlatches each hook that connects the top cover to the phone.
      • Repeat for both the left and the right sides of the phone.
      • Place the top cover aside once the top cover is completely disconnected from the phone.
      Ask FixBot
    1. Nokia 6086 Screen Replacement, Screen: step 7, image 1 of 3 Nokia 6086 Screen Replacement, Screen: step 7, image 2 of 3 Nokia 6086 Screen Replacement, Screen: step 7, image 3 of 3
      • Locate the four screws on the phone.
      • The top right screw is located under the black connector piece.
      • To remove the connector piece gently lift it off of its connector.
      • Take the T6 driver and remove the screws.
      Ask FixBot
    2. Nokia 6086 Screen Replacement: step 8, image 1 of 1
      • Carefully lift up the motherboard.
      Ask FixBot
    3. Nokia 6086 Screen Replacement: step 9, image 1 of 2 Nokia 6086 Screen Replacement: step 9, image 2 of 2
      • Find the orange slip on the motherboard.
      • Peel back the orange slip to expose the screen.
      Ask FixBot
    4. Nokia 6086 Screen Replacement: step 10, image 1 of 3 Nokia 6086 Screen Replacement: step 10, image 2 of 3 Nokia 6086 Screen Replacement: step 10, image 3 of 3
      • Place the ipod opening tool under the screen.
      • Remove the damaged screen with the ipod opening tool.
      Ask FixBot
Author
with
Caitlin Rahm
78 Reputation
4 Guides authored
Cal Poly, Team 26-30, Regan Spring 2010 Member of Cal Poly, Team 26-30, Regan Spring 2010
CPSU-REGAN-S10S26G30
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 81
All Time: 4,171
