Nokia 6086 Logic Board Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
78
All Time:
2,241
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
Replacing the PCB or logic board of the phone.
Tools
    1. Nokia 6086 Logic Board Replacement, Battery: step 1, image 1 of 1
      • Turn off the phone.
      • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
      • Position the phone so that the back side is in view.
      Ask FixBot
    2. Nokia 6086 Logic Board Replacement: step 2, image 1 of 3 Nokia 6086 Logic Board Replacement: step 2, image 2 of 3 Nokia 6086 Logic Board Replacement: step 2, image 3 of 3
      • Remove the back battery cover.
      • Apply pressure on the cover while simultaneously sliding the cover downward.
      Ask FixBot
    3. Nokia 6086 Logic Board Replacement: step 3, image 1 of 3 Nokia 6086 Logic Board Replacement: step 3, image 2 of 3 Nokia 6086 Logic Board Replacement: step 3, image 3 of 3
      • Insert the iPod opening tool between the base of the phone and the phone battery.
      • Position the phone so that the battery won't fall out of the phone.
      • The battery lifts out of the phone fast and easily.
      • Carefully lift the battery out of the phone.
      Ask FixBot
    1. Nokia 6086 Logic Board Replacement, Upper Back Cover: step 4, image 1 of 1
      • Turn the phone so that the back of the phone is facing forward.
      • The picture to the left shows the location of the plastic tabs that attach to the upper cover of the phone.
      • In this picture, the upper cover has already been removed.
      Ask FixBot
    2. Nokia 6086 Logic Board Replacement: step 5, image 1 of 2 Nokia 6086 Logic Board Replacement: step 5, image 2 of 2
      • Place the iPod opening tool under the tabs near the top of the phone.
      • Slide the iPod Opening Tool upwards.
      • This will pop the tabs and release the upper part of the phone.
      • Repeat for the left and the right sides.
      Ask FixBot
    3. Nokia 6086 Logic Board Replacement: step 6, image 1 of 2 Nokia 6086 Logic Board Replacement: step 6, image 2 of 2
      • Place the iPod opening tool at the top area of the bottom section of the phone (indicated in picture).
      • Lift the iPod opening tool to pop open the clips.
      • This will release the upper back cover of the phone.
      Ask FixBot
    4. Nokia 6086 Logic Board Replacement: step 7, image 1 of 3 Nokia 6086 Logic Board Replacement: step 7, image 2 of 3 Nokia 6086 Logic Board Replacement: step 7, image 3 of 3
      • Push upward on the top back cover using two thumbs.
      • This will remove the top back cover from the phone.
      Ask FixBot
    1. Nokia 6086 Logic Board Replacement, Base of The Phone: step 8, image 1 of 2 Nokia 6086 Logic Board Replacement, Base of The Phone: step 8, image 2 of 2
      • Locate the four screws.
      • Remove the screws using a T6 Torx screwdriver.
      Ask FixBot
    2. Nokia 6086 Logic Board Replacement: step 9, image 1 of 2 Nokia 6086 Logic Board Replacement: step 9, image 2 of 2
      • Turn the phone over.
      • Gently pull apart the phone.
      • Start at the bottom of the phone and pull outward.
      • There are plastic catches on the middle of each side. These should pop free as you pull.
      • Be careful, the phone will separate into two sections.
      Ask FixBot
    3. Nokia 6086 Logic Board Replacement: step 10, image 1 of 2 Nokia 6086 Logic Board Replacement: step 10, image 2 of 2
      • The phone should now be in two different sections.
      • 1) The logic board and the back cover
      • 2) The keypad and the rest of the phone
      Ask FixBot
    1. Nokia 6086 Logic Board Replacement, Logic Board: step 11, image 1 of 2 Nokia 6086 Logic Board Replacement, Logic Board: step 11, image 2 of 2
      • Remove the logic board from the back cover of the phone.
      Ask FixBot
Andrea
70 Reputation
5 Guides authored
Cal Poly, Team 26-30, Regan Spring 2010 Member of Cal Poly, Team 26-30, Regan Spring 2010
CPSU-REGAN-S10S26G30
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 78
All Time: 2,241
