Nokia 6085h Battery Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
0
Past 7 Days:
19
Past 30 Days:
110
All Time:
2,365
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 minute
Difficulty: Very easy
Introduction
Go to step 1 ↓
If your Nokia (model 6085h) phone happens to malfunction, you most likely have a worn-out battery, in which requires replacement.
A battery on a Nokia phone helps gain access to features, for example, making & receiving phone calls. Throughout the usage, the battery slowly drains when going through the charging process. If you notice that your phone is wasting more battery than usual, you should replace the battery.
In this guide, you will be able to find out where the battery is located, and how to remove the battery safely.
Before beginning, make sure your device is powered off and disconnected from any external power source(s). Have the new battery ready and set to the side.
    1. Nokia 6085h Battery Replacement, Battery: step 1, image 1 of 1
      • Flip over the phone so that the back is facing up.
      • Pressing your thumb against the back cover, slide the cover off of the phone.
      Ask FixBot
    2. Nokia 6085h Battery Replacement: step 2, image 1 of 1
      • Remove the phone's battery.
      Ask FixBot
3 other people completed this guide.
Justin Blonigan
46 Reputation
1 Guide authored
Cal Poly, Team 4-46, Amido Fall 2010 Member of Cal Poly, Team 4-46, Amido Fall 2010
CPSU-AMIDO-F10S4G46
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 19
Past 30 Days: 110
All Time: 2,365
