Up to 20% off select tools
Nokia 6061 Screen Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
5
Past 7 Days:
20
Past 30 Days:
97
All Time:
1,752
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Gather tools needed. Have a small tray or container on hand to hold screws and cell phone parts as you disassemble and reassemble the Nokia 6061.
    1. Nokia 6061 Screen Replacement, Screen: step 1, image 1 of 3 Nokia 6061 Screen Replacement, Screen: step 1, image 2 of 3 Nokia 6061 Screen Replacement, Screen: step 1, image 3 of 3
      • Gather the necessary tools:
      • T6 Torx screwdriver
      • Plastic opening tool
      • Small flathead screwdriver
      Ask FixBot
    2. Nokia 6061 Screen Replacement: step 2, image 1 of 1
      • This guide will show you how to replace the LCD—after it's been dropped one too many times.
      Ask FixBot
    3. Nokia 6061 Screen Replacement: step 3, image 1 of 1
      Tool used on this step:
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      Buy
      • Using a 2.0 flathead screwdriver, pry open and remove the black, plastic strip (beneath the screen) to reveal the 2 screws holding the screen in place.
      Ask FixBot
    4. Nokia 6061 Screen Replacement: step 4, image 1 of 1
      • Remove the two T6 Torx screws from the base of the display.
      Ask FixBot
    5. Nokia 6061 Screen Replacement: step 5, image 1 of 3 Nokia 6061 Screen Replacement: step 5, image 2 of 3 Nokia 6061 Screen Replacement: step 5, image 3 of 3
      • Once the screws are removed, flip the phone shut.
      • Insert the plastic opening tool at the position indicated and pry along the seam between the front cover and display.
      • Continue prying along the perimeter of the front cover until it is free from the phone.
      Ask FixBot
    6. Nokia 6061 Screen Replacement: step 6, image 1 of 2 Nokia 6061 Screen Replacement: step 6, image 2 of 2
      • Use a plastic opening tool to pry the LCD circuit board up and out of the phone.
      • Be careful not to damage the circuit board.
      • Flip the display up and over to expose its ribbon cable connector.
      Ask FixBot
    7. Nokia 6061 Screen Replacement: step 7, image 1 of 3 Nokia 6061 Screen Replacement: step 7, image 2 of 3 Nokia 6061 Screen Replacement: step 7, image 3 of 3
      • Use a plastic opening tool to gently pry the LCD ribbon cable connector up out its socket on the LCD circuit board.
      • The other two photos show the male and female sides of the small green connector. Make sure they snap together tightly when the new display is attached.
      Ask FixBot
    8. Nokia 6061 Screen Replacement: step 8, image 1 of 1
      • To reassemble your phone, reattach the display to the phone by reconnecting the display ribbon cable. Place the screen assembly back into the front case of the phone.
      Ask FixBot
    9. Nokia 6061 Screen Replacement: step 9, image 1 of 1
      • Replace the phone cover by applying pressure until a click is heard.
      Ask FixBot
    10. Nokia 6061 Screen Replacement: step 10, image 1 of 1
      • With the cover reattached, flip the phone into the open position and replace the screws removed in step 3. The screw-holes are indicated in the photo.
      • Replace the black, plastic strip by applying pressure until the strip audibly clicks into place.
      Ask FixBot
Finish Line
Author
with
rosin7
61 Reputation
2 Guides authored
Ohio State, Team 1-3, Buehl Spring 2013 Member of Ohio State, Team 1-3, Buehl Spring 2013
OSU-BUEHL-S13S1G3
4 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 97
All Time: 1,752
