Up to 20% off select tools
Nokia 6030 SIM Card Replacement
Views: 5.4K
View statistics:
Past 24 Hours:
5
Past 7 Days:
18
Past 30 Days:
88
All Time:
5,440
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Very easy
Student In Progress
This guide is being worked on by hardworking students.
Introduction
Go to step 1 ↓
This guide provides instructions on how to install a new SIM card for a Nokia 6030.
This project is intended for Nokia 6030 users who want to replace an old SIM card for a variety of reasons, such as switching to a different carrier or having a defective SIM card. Installation of a new SIM card on the Nokia 6030 allows users to continue using the phone if he or she wants to switch to a different carrier without having to purchase a new phone.
In order to successfully perform all the instructions below, no special skills or requirements are needed. Please keep in mind that this guide requires close attention to detail and caution when performing the tasks to avoid injuries. Make sure to power off your phone completely and disconnect from any external power source prior to beginning this guide.
    1. Nokia 6030 SIM Card Replacement, Battery: step 1, image 1 of 3 Nokia 6030 SIM Card Replacement, Battery: step 1, image 2 of 3 Nokia 6030 SIM Card Replacement, Battery: step 1, image 3 of 3
      • Press down on the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
      Ask FixBot
    2. Nokia 6030 SIM Card Replacement: step 2, image 1 of 3 Nokia 6030 SIM Card Replacement: step 2, image 2 of 3 Nokia 6030 SIM Card Replacement: step 2, image 3 of 3
      • Use your finger to gently pull the bottom of the battery up by using the slip found at the bottom of the phone.
      • Lift out battery and remove.
      Ask FixBot
    1. Nokia 6030 SIM Card Replacement, SIM Card: step 3, image 1 of 3 Nokia 6030 SIM Card Replacement, SIM Card: step 3, image 2 of 3 Nokia 6030 SIM Card Replacement, SIM Card: step 3, image 3 of 3
      • Use your finger to lift the metal cage up.
      • Remove SIM card.
      Ask FixBot
    2. Nokia 6030 SIM Card Replacement: step 4, image 1 of 1
      • Use your finger to close the metal cage.
      Ask FixBot
Author
with
Spencer Woodworth
346 Reputation
9 Guides authored
Cal Poly, Team 23-63, Johann Spring 2010 Member of Cal Poly, Team 23-63, Johann Spring 2010
CPSU-JOHANN-S10S23G63
3 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 88
All Time: 5,440
