Up to 20% off select tools
Nokia 6030 LCD Screen Replacement
Views: 7.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
86
All Time:
7,833
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 6 minutes
Difficulty: Moderate
Student In Progress
This guide is being worked on by hardworking students.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
Replacing LCD Screen.
    1. Nokia 6030 LCD Screen Replacement, Battery: step 1, image 1 of 3 Nokia 6030 LCD Screen Replacement, Battery: step 1, image 2 of 3 Nokia 6030 LCD Screen Replacement, Battery: step 1, image 3 of 3
      • Press down on the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
      Ask FixBot
    2. Nokia 6030 LCD Screen Replacement: step 2, image 1 of 3 Nokia 6030 LCD Screen Replacement: step 2, image 2 of 3 Nokia 6030 LCD Screen Replacement: step 2, image 3 of 3
      • Use your finger to gently pull the bottom of the battery up by using the slip found at the bottom of the phone.
      • Lift out battery and remove.
      Ask FixBot
    1. Nokia 6030 LCD Screen Replacement, SIM Card: step 3, image 1 of 3 Nokia 6030 LCD Screen Replacement, SIM Card: step 3, image 2 of 3 Nokia 6030 LCD Screen Replacement, SIM Card: step 3, image 3 of 3
      • Use your finger to lift the metal cage up.
      • Remove SIM card.
      Ask FixBot
    2. Nokia 6030 LCD Screen Replacement: step 4, image 1 of 1
      • Use your finger to close the metal cage.
      Ask FixBot
    1. Nokia 6030 LCD Screen Replacement, Front Cover: step 5, image 1 of 3 Nokia 6030 LCD Screen Replacement, Front Cover: step 5, image 2 of 3 Nokia 6030 LCD Screen Replacement, Front Cover: step 5, image 3 of 3
      • Insert your two fingers under the two tabs found at the top of the phone underneath the black casing, then pull the casing up and slide it out slowly.
      Ask FixBot
    2. Nokia 6030 LCD Screen Replacement: step 6, image 1 of 2 Nokia 6030 LCD Screen Replacement: step 6, image 2 of 2
      • After removing the top cover, turn the phone over so the screen is facing upwards.
      Ask FixBot
    3. Nokia 6030 LCD Screen Replacement: step 7, image 1 of 3 Nokia 6030 LCD Screen Replacement: step 7, image 2 of 3 Nokia 6030 LCD Screen Replacement: step 7, image 3 of 3
      • Use your fingers to slowly lift the screen back towards the bottom of the phone using the arrows found at the top of the phone.
      Ask FixBot
    1. Nokia 6030 LCD Screen Replacement, LCD Screen: step 8, image 1 of 3 Nokia 6030 LCD Screen Replacement, LCD Screen: step 8, image 2 of 3 Nokia 6030 LCD Screen Replacement, LCD Screen: step 8, image 3 of 3
      • Remove the six screws found along the frame of the phone with a T6 Torx screwdriver and put them to the side.
      Ask FixBot
    2. Nokia 6030 LCD Screen Replacement: step 9, image 1 of 3 Nokia 6030 LCD Screen Replacement: step 9, image 2 of 3 Nokia 6030 LCD Screen Replacement: step 9, image 3 of 3
      • Gently lift the top of the screen up.
      • Be cautious of loose parts.
      Ask FixBot
    3. Nokia 6030 LCD Screen Replacement: step 10, image 1 of 3 Nokia 6030 LCD Screen Replacement: step 10, image 2 of 3 Nokia 6030 LCD Screen Replacement: step 10, image 3 of 3
      • Gently pull up on the grey plastic tab.
      Ask FixBot
2 other people completed this guide.
Author
with
Spencer Woodworth
346 Reputation
9 Guides authored
Cal Poly, Team 23-63, Johann Spring 2010 Member of Cal Poly, Team 23-63, Johann Spring 2010
CPSU-JOHANN-S10S23G63
3 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 86
All Time: 7,833
