Up to 20% off select tools
Nokia 6030 Keypad Replacement
Views: 3.6K
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
90
All Time:
3,609
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Student In Progress
This guide is being worked on by hardworking students.
Introduction
Go to step 1 ↓
If your Nokia 6030’s keypad works inconsistently, you may need to replace the old keypad with a new one.
After extended use, cell phone keypads become unresponsive. A faulty keypad causes frustrating experiences when attempting to type something on the device or to call someone.
This guide provides step-by-step instructions on replacing your Nokia 6030’s keypad, without the need for any special skills or tools.
    1. Nokia 6030 Keypad Replacement, Battery: step 1, image 1 of 3 Nokia 6030 Keypad Replacement, Battery: step 1, image 2 of 3 Nokia 6030 Keypad Replacement, Battery: step 1, image 3 of 3
      • Press down on the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
      Ask FixBot
    2. Nokia 6030 Keypad Replacement: step 2, image 1 of 3 Nokia 6030 Keypad Replacement: step 2, image 2 of 3 Nokia 6030 Keypad Replacement: step 2, image 3 of 3
      • Use your finger to gently pull the bottom of the battery up by using the slip found at the bottom of the phone.
      • Lift out battery and remove.
      Ask FixBot
    1. Nokia 6030 Keypad Replacement, SIM Card: step 3, image 1 of 3 Nokia 6030 Keypad Replacement, SIM Card: step 3, image 2 of 3 Nokia 6030 Keypad Replacement, SIM Card: step 3, image 3 of 3
      • Use your finger to lift the metal cage up.
      • Remove SIM card.
      Ask FixBot
    2. Nokia 6030 Keypad Replacement: step 4, image 1 of 1
      • Use your finger to close the metal cage.
      Ask FixBot
    1. Nokia 6030 Keypad Replacement, Front Cover: step 5, image 1 of 3 Nokia 6030 Keypad Replacement, Front Cover: step 5, image 2 of 3 Nokia 6030 Keypad Replacement, Front Cover: step 5, image 3 of 3
      • Insert your two fingers under the two tabs found at the top of the phone underneath the black casing, then pull the casing up and slide it out slowly.
      Ask FixBot
    2. Nokia 6030 Keypad Replacement: step 6, image 1 of 2 Nokia 6030 Keypad Replacement: step 6, image 2 of 2
      • After removing the top cover, turn the phone over so the screen is facing upwards.
      Ask FixBot
    3. Nokia 6030 Keypad Replacement: step 7, image 1 of 3 Nokia 6030 Keypad Replacement: step 7, image 2 of 3 Nokia 6030 Keypad Replacement: step 7, image 3 of 3
      • Use your fingers to slowly lift the screen back towards the bottom of the phone using the arrows found at the top of the phone.
      Ask FixBot
    1. Nokia 6030 Keypad Replacement, Keypad: step 8, image 1 of 2 Nokia 6030 Keypad Replacement, Keypad: step 8, image 2 of 2
      • Gently pull the rubber away from the front screen and the buttons will detach from the plastic case.
      Ask FixBot
    2. Nokia 6030 Keypad Replacement: step 9, image 1 of 2 Nokia 6030 Keypad Replacement: step 9, image 2 of 2
      • Remove old keypad and replace it with new keypad.
      Ask FixBot
Author
with
Spencer Woodworth
346 Reputation
9 Guides authored
Cal Poly, Team 23-63, Johann Spring 2010 Member of Cal Poly, Team 23-63, Johann Spring 2010
CPSU-JOHANN-S10S23G63
3 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 90
All Time: 3,609
