Student In Progress
This guide is being worked on by hardworking students.
Introduction
Go to step 1 ↓The front cover of the Nokia 6030 serves as a protector for the front part of the phone, including the screen. The Nokia 6030 can undergo malfunctions and/or the glass protector can break which may require the removal of the front cover for inspection or for replacement purposes.
Follow this guide to help you remove the glass/front cover of your Nokia 6030.
Press down on the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
Insert your two fingers under the two tabs found at the top of the phone underneath the black casing, then pull the casing up and slide it out slowly.
