Up to 20% off select tools
Nokia 6030 Battery Replacement
Views: 4.3K
View statistics:
Past 24 Hours:
0
Past 7 Days:
3
Past 30 Days:
34
All Time:
4,329
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Student In Progress
This guide is being worked on by hardworking students.
Introduction
Go to step 1 ↓
When a Nokia 6030 experiences a power failure due to a dead battery, a quick replacement usually fixes the issue. No special skills or tools are required; you only need the phone and your hands. Because the battery is fully removable, you can easily replace it by sliding off the phone's back cover. The only external item you might need is a new replacement battery. Once replaced, your phone will be fully functional and will typically experience fewer power-related issues than before.
    1. Nokia 6030 Battery Replacement, Battery: step 1, image 1 of 3 Nokia 6030 Battery Replacement, Battery: step 1, image 2 of 3 Nokia 6030 Battery Replacement, Battery: step 1, image 3 of 3
      • Press down on the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
      Ask FixBot
    2. Nokia 6030 Battery Replacement: step 2, image 1 of 3 Nokia 6030 Battery Replacement: step 2, image 2 of 3 Nokia 6030 Battery Replacement: step 2, image 3 of 3
      • Use your finger to gently pull the bottom of the battery up by using the slip found at the bottom of the phone.
      • Lift out battery and remove.
      Ask FixBot
3 other people completed this guide.
Author
with
Spencer Woodworth
346 Reputation
9 Guides authored
Cal Poly, Team 23-63, Johann Spring 2010 Member of Cal Poly, Team 23-63, Johann Spring 2010
CPSU-JOHANN-S10S23G63
3 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 34
All Time: 4,329
