Nokia 6010 vibrator motor replacement
  1. Nokia 6010 vibrator motor replacement, Battery: step 1, image 1 of 3 Nokia 6010 vibrator motor replacement, Battery: step 1, image 2 of 3 Nokia 6010 vibrator motor replacement, Battery: step 1, image 3 of 3
    • Press the small tab on the bottom of the back of the phone.
    • Push the back case upward towards the power button. The back case will then pop off.
    • It requires some force, so be careful.
    Ask FixBot
  2. Nokia 6010 vibrator motor replacement: step 2, image 1 of 2 Nokia 6010 vibrator motor replacement: step 2, image 2 of 2
    • Lift the battery near the bottom and pry up.
    Ask FixBot
  3. Nokia 6010 vibrator motor replacement, SIM Card: step 3, image 1 of 1
    • With one hand, press the ridged tab near the visible side of the SIM card.
    • Slide the card out with your other hand.
    Ask FixBot
  4. Nokia 6010 vibrator motor replacement, Keypad: step 4, image 1 of 2 Nokia 6010 vibrator motor replacement, Keypad: step 4, image 2 of 2
    • Grip the phone on either the sides, the top, or the bottom.
    • Pull the front case away from the rest of the phone.
    • There are no special tabs to keep it in place so it should wiggle free easily.
    Ask FixBot
  5. Nokia 6010 vibrator motor replacement: step 5, image 1 of 1
    • Lift the keypad away from the body of the phone.
    • The keypad is the rubber-backed piece with the number keys.
    Ask FixBot
  6. Nokia 6010 vibrator motor replacement, LCD Screen and Speaker: step 6, image 1 of 2 Nokia 6010 vibrator motor replacement, LCD Screen and Speaker: step 6, image 2 of 2
    • Remove the six screws around the front of the phone body with a T6 screwdriver.
    Ask FixBot
  7. Nokia 6010 vibrator motor replacement: step 7, image 1 of 3 Nokia 6010 vibrator motor replacement: step 7, image 2 of 3 Nokia 6010 vibrator motor replacement: step 7, image 3 of 3
    • Insert your finger underneath the speaker piece and pry away from the phone body.
    • The plastic layer containing the LCD screen and speaker takes some force to remove.
    • There are 4 plastic tabs which keep it in place, but they are hard to press. Be careful and go tab by tab or use a spudger if you are nervous about using too much force.
    • The LCD and the speaker are attached to the same piece and must be replaced together.
    Ask FixBot
  8. Nokia 6010 vibrator motor replacement, Logic Board: step 8, image 1 of 2 Nokia 6010 vibrator motor replacement, Logic Board: step 8, image 2 of 2
    • Slide the rubber power button away from the body of the phone.
    • The power button is the rubber piece on the top of the phone.
    Ask FixBot
  9. Nokia 6010 vibrator motor replacement: step 9, image 1 of 3 Nokia 6010 vibrator motor replacement: step 9, image 2 of 3 Nokia 6010 vibrator motor replacement: step 9, image 3 of 3
    • Insert a finger between the phone body and logic board.
    • The logic board is the green plastic piece with circuitry attached.
    • Pull the board away gently.
    • The board is delicate and contains electronic parts. Be careful while removing it.
    Ask FixBot
  10. Nokia 6010 vibrator motor replacement, Vibrator: step 10, image 1 of 3 Nokia 6010 vibrator motor replacement, Vibrator: step 10, image 2 of 3 Nokia 6010 vibrator motor replacement, Vibrator: step 10, image 3 of 3
    • Insert a spudger beneath the metallic shaft of the vibrator and pry it away from the phone.
    • The vibrator is the small orange box located near the bottom of the phone.
    Ask FixBot
Nicholas Hanne
129 Reputation
8 Guides authored
Cal Poly, Team 14-45, Regan Winter 2010 Member of Cal Poly, Team 14-45, Regan Winter 2010
CPSU-REGAN-W10S14G45
5 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 2,827
