Nokia 6010 Charger Connector Replacement
    1. Nokia 6010 Charger Connector Replacement, Battery: step 1, image 1 of 3 Nokia 6010 Charger Connector Replacement, Battery: step 1, image 2 of 3 Nokia 6010 Charger Connector Replacement, Battery: step 1, image 3 of 3
      • Press the small tab on the bottom of the back of the phone.
      • Push the back case upward towards the power button. The back case will then pop off.
      • It requires some force, so be careful.
      Ask FixBot
    2. Nokia 6010 Charger Connector Replacement: step 2, image 1 of 2 Nokia 6010 Charger Connector Replacement: step 2, image 2 of 2
      • Lift the battery near the bottom and pry up.
      Ask FixBot
    1. Nokia 6010 Charger Connector Replacement, SIM Card: step 3, image 1 of 1
      • With one hand, press the ridged tab near the visible side of the SIM card.
      • Slide the card out with your other hand.
      Ask FixBot
    1. Nokia 6010 Charger Connector Replacement, Keypad: step 4, image 1 of 2 Nokia 6010 Charger Connector Replacement, Keypad: step 4, image 2 of 2
      • Grip the phone on either the sides, the top, or the bottom.
      • Pull the front case away from the rest of the phone.
      • There are no special tabs to keep it in place so it should wiggle free easily.
      Ask FixBot
    2. Nokia 6010 Charger Connector Replacement: step 5, image 1 of 1
      • Lift the keypad away from the body of the phone.
      • The keypad is the rubber-backed piece with the number keys.
      Ask FixBot
    1. Nokia 6010 Charger Connector Replacement, LCD Screen and Speaker: step 6, image 1 of 2 Nokia 6010 Charger Connector Replacement, LCD Screen and Speaker: step 6, image 2 of 2
      • Remove the six screws around the front of the phone body with a T6 screwdriver.
      Ask FixBot
    2. Nokia 6010 Charger Connector Replacement: step 7, image 1 of 3 Nokia 6010 Charger Connector Replacement: step 7, image 2 of 3 Nokia 6010 Charger Connector Replacement: step 7, image 3 of 3
      • Insert your finger underneath the speaker piece and pry away from the phone body.
      • The plastic layer containing the LCD screen and speaker takes some force to remove.
      • There are 4 plastic tabs which keep it in place, but they are hard to press. Be careful and go tab by tab or use a spudger if you are nervous about using too much force.
      • The LCD and the speaker are attached to the same piece and must be replaced together.
      Ask FixBot
    1. Nokia 6010 Charger Connector Replacement, Logic Board: step 8, image 1 of 2 Nokia 6010 Charger Connector Replacement, Logic Board: step 8, image 2 of 2
      • Slide the rubber power button away from the body of the phone.
      • The power button is the rubber piece on the top of the phone.
      Ask FixBot
    2. Nokia 6010 Charger Connector Replacement: step 9, image 1 of 3 Nokia 6010 Charger Connector Replacement: step 9, image 2 of 3 Nokia 6010 Charger Connector Replacement: step 9, image 3 of 3
      • Insert a finger between the phone body and logic board.
      • The logic board is the green plastic piece with circuitry attached.
      • Pull the board away gently.
      • The board is delicate and contains electronic parts. Be careful while removing it.
      Ask FixBot
    1. Nokia 6010 Charger Connector Replacement, Charger Connector: step 10, image 1 of 3 Nokia 6010 Charger Connector Replacement, Charger Connector: step 10, image 2 of 3 Nokia 6010 Charger Connector Replacement, Charger Connector: step 10, image 3 of 3
      • Insert a spudger tool between the phone casing and the charger connector.
      • Pry the key away from the phone gently.
      • Be careful not to bend the metal leads while handling the power key.
      Ask FixBot
Nicholas Hanne
129 Reputation
8 Guides authored
Cal Poly, Team 14-45, Regan Winter 2010 Member of Cal Poly, Team 14-45, Regan Winter 2010
CPSU-REGAN-W10S14G45
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 39
All Time: 4,703
