Nokia 6 Loudspeaker Replacement
    1. Nokia 6 Loudspeaker Replacement, Display Assembly: step 1, image 1 of 3 Nokia 6 Loudspeaker Replacement, Display Assembly: step 1, image 2 of 3 Nokia 6 Loudspeaker Replacement, Display Assembly: step 1, image 3 of 3
      • Power off your Nokia 6 before beginning disassembly.
      • Insert the SIM card ejection tool into the hole on the left side of the phone.
      • Remove the SIM card and microSD card.
      Ask FixBot
    2. Nokia 6 Loudspeaker Replacement: step 2, image 1 of 1
      • If your display glass is cracked, take precaution by taping over the display to prevent further breakage and harm.
      • Lay overlapping strips of clear packing tape over the Nokia 6's display until the whole screen is covered.
      Ask FixBot
    3. Nokia 6 Loudspeaker Replacement: step 3, image 1 of 1
      • To soften the adhesive, use a heat gun and heat one edge of the phone for five minutes.
      • To use the heat gun, plug it into an outlet.
      • When the heat gun is plugged in, the heat gun automatically turns on and will start blowing hot air.
      Ask FixBot
    4. Nokia 6 Loudspeaker Replacement: step 4, image 1 of 1
      • Take a Jimmy and slide it under the glass after the adhesive has been softened.
      • Place a pick under the glass after lifting with the pry tool so that the screen won't re-adhere to the frame again.
      • Make sure to not touch the LCD edge underneath the glass layer with the metal pry tool or the cards. This can damage the ribbon cables underneath and compromise the structural integrity of the phone itself.
      • The corners of the screen are the most fragile part of the screen. Make sure that the entire edge of the screen is dislodged from the frame before prying at the corners.
      Ask FixBot
    5. Nokia 6 Loudspeaker Replacement: step 5, image 1 of 1
      • Lift the screen off of the phone.
      Ask FixBot
    6. Nokia 6 Loudspeaker Replacement: step 6, image 1 of 2 Nokia 6 Loudspeaker Replacement: step 6, image 2 of 2
      • Use a Phillips #000 screwdriver to remove the 1 mm x 1.4 mm screw holding down the metal bracket over the screen ribbon connector.
      Ask FixBot
    7. Nokia 6 Loudspeaker Replacement: step 7, image 1 of 1
      • Remove the metal bracket with a tweezer.
      Ask FixBot
    8. Nokia 6 Loudspeaker Replacement: step 8, image 1 of 1
      • Use a spudger to disconnect the screen ribbon connector and free the display assembly.
      • The corners and edge of the LCD are fragile. Be careful attaching it to the back of the phone.
      • Carefully remove the screen from the device.
      Ask FixBot
    1. Nokia 6 Loudspeaker Replacement, Home Button Assembly: step 9, image 1 of 1
      • Disconnect the battery connector with a spudger.
      Ask FixBot
    2. Nokia 6 Loudspeaker Replacement: step 10, image 1 of 2 Nokia 6 Loudspeaker Replacement: step 10, image 2 of 2
      Tool used on this step:
      Buy
      • Use a Phillips #00 screwdriver to remove the 1.2 mm x 2.2 mm screw in the upper hand corner of the phone.
      • Use tweezers to remove the bracket.
      Ask FixBot
    3. Nokia 6 Loudspeaker Replacement: step 11, image 1 of 2 Nokia 6 Loudspeaker Replacement: step 11, image 2 of 2
      • Detach the cable with the black nylon spudger.
      • Detach the home button and remove it from the device.
      Ask FixBot
    1. Nokia 6 Loudspeaker Replacement, Midframe: step 12, image 1 of 1
      • Remove 18 screws.
      • There is one 1 mm x 1.4 mm screw that needs to be removed by a Phillips #000 screwdriver.
      • One of the screws is 1.2 mm x 4.2 mm and will be removed by a Phillips #00.
      • The remaining 16 screws can be removed by the Phillips #00 screwdriver and are 1.2 mm x 2.2 mm.
      Ask FixBot
    2. Nokia 6 Loudspeaker Replacement: step 13, image 1 of 2 Nokia 6 Loudspeaker Replacement: step 13, image 2 of 2
      • Decouple the midframe with the spudger and remove the midframe from the device.
      Ask FixBot
    1. Nokia 6 Loudspeaker Replacement, Motherboard: step 14, image 1 of 2 Nokia 6 Loudspeaker Replacement, Motherboard: step 14, image 2 of 2
      Buy
      Ask FixBot
    2. Nokia 6 Loudspeaker Replacement: step 15, image 1 of 3 Nokia 6 Loudspeaker Replacement: step 15, image 2 of 3 Nokia 6 Loudspeaker Replacement: step 15, image 3 of 3
      • Detach the two cables with the spudger.
      • Detach the cable with a pair of tweezers.
      • Be careful when detaching the cables, make sure to not completely remove the cables from the phone!
      Ask FixBot
    3. Nokia 6 Loudspeaker Replacement: step 16, image 1 of 1
      • Remove six screws.
      • Two of these screws are 1.0 mm x 1.4 mm and need to be removed by a Phillips #000 screwdriver.
      • The remaining four screws are 1.2 mm x 2.2 mm and are removed by a Phillips #00 screwdriver.
      Ask FixBot
    4. Nokia 6 Loudspeaker Replacement: step 17, image 1 of 2 Nokia 6 Loudspeaker Replacement: step 17, image 2 of 2
      • Remove the motherboard from the Nokia 6 with the spudger.
      • Be careful because the motherboard is fragile. Wiggle it gently to remove it.
      Ask FixBot
    1. Nokia 6 Loudspeaker Replacement, Microphone: step 18, image 1 of 1
      Buy
      • With tweezers, lift the wire by the microUSB port and the microphone unit.
      Ask FixBot
    2. Nokia 6 Loudspeaker Replacement: step 19, image 1 of 1
      • Remove three screws.
      • Two of these are 1 mm x 1.4 mm and can be removed by a Phillips #000.
      • One of the screws is 1.2 mm x 2.2 mm and can be removed by a Phillips #00.
      Ask FixBot
    3. Nokia 6 Loudspeaker Replacement: step 20, image 1 of 2 Nokia 6 Loudspeaker Replacement: step 20, image 2 of 2
      • Remove the microUSB port and the microphone by lifting the unit with a spudger.
      • Lift the black strip gently with the spudger, make sure not to rip it.
      Ask FixBot
    1. Nokia 6 Loudspeaker Replacement, Loudspeaker: step 21, image 1 of 2 Nokia 6 Loudspeaker Replacement, Loudspeaker: step 21, image 2 of 2
      • Use a spudger to remove the loudspeaker from the phone.
      Ask FixBot
Chrissy Robins
1,603 Reputation
10 Guides authored
Cal Poly, Team S9-G15, Maness Spring 2019 Member of Cal Poly, Team S9-G15, Maness Spring 2019
CPSU-MANESS-S19S9G15
4 Members
120 Guides authored
1 Guide Comment
Great article and just one question. “To reassemble your device, follow these instructions in reverse order.” That’s ok until the screen needs to be glued back so advice on doing that would be appreciated.
murraysnudge - Reply Share
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 63
All Time: 1,929
