Up to 20% off select tools
Nokia 6 Home Button Assembly Replacement
Views: 3.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
23
Past 30 Days:
70
All Time:
3,681
Comments: 8
7 comments on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 - 50 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a faulty home button assembly in your Nokia 6 smart phone.
The home button assembly is the component of the device that is responsible for navigation and bio-metric authentication. Your home button may need to be replaced if it is becoming unresponsive making it harder to navigate the device.
This repair makes use of a heat gun to weaken the adhesive of the smart phone. If you are unfamiliar with using heat guns, consult this guide.
For your safety, make sure to power down the device before beginning the repair.
    1. Nokia 6 Home Button Assembly Replacement, Display Assembly: step 1, image 1 of 3 Nokia 6 Home Button Assembly Replacement, Display Assembly: step 1, image 2 of 3 Nokia 6 Home Button Assembly Replacement, Display Assembly: step 1, image 3 of 3
      • Power off your Nokia 6 before beginning disassembly.
      • Insert the SIM card ejection tool into the hole on the left side of the phone.
      • Remove the SIM card and microSD card.
      Ask FixBot
    2. Nokia 6 Home Button Assembly Replacement: step 2, image 1 of 1
      • If your display glass is cracked, take precaution by taping over the display to prevent further breakage and harm.
      • Lay overlapping strips of clear packing tape over the Nokia 6's display until the whole screen is covered.
      Ask FixBot
    3. Nokia 6 Home Button Assembly Replacement: step 3, image 1 of 1
      • To soften the adhesive, use a heat gun and heat one edge of the phone for five minutes.
      • To use the heat gun, plug it into an outlet.
      • When the heat gun is plugged in, the heat gun automatically turns on and will start blowing hot air.
      Ask FixBot
    4. Nokia 6 Home Button Assembly Replacement: step 4, image 1 of 1
      • Take a Jimmy and slide it under the glass after the adhesive has been softened.
      • Place a pick under the glass after lifting with the pry tool so that the screen won't re-adhere to the frame again.
      • Make sure to not touch the LCD edge underneath the glass layer with the metal pry tool or the cards. This can damage the ribbon cables underneath and compromise the structural integrity of the phone itself.
      • The corners of the screen are the most fragile part of the screen. Make sure that the entire edge of the screen is dislodged from the frame before prying at the corners.
      Ask FixBot
    5. Nokia 6 Home Button Assembly Replacement: step 5, image 1 of 1
      • Lift the screen off of the phone.
      Ask FixBot
    6. Nokia 6 Home Button Assembly Replacement: step 6, image 1 of 2 Nokia 6 Home Button Assembly Replacement: step 6, image 2 of 2
      • Use a Phillips #000 screwdriver to remove the 1 mm x 1.4 mm screw holding down the metal bracket over the screen ribbon connector.
      Ask FixBot
    7. Nokia 6 Home Button Assembly Replacement: step 7, image 1 of 1
      • Remove the metal bracket with a tweezer.
      Ask FixBot
    8. Nokia 6 Home Button Assembly Replacement: step 8, image 1 of 1
      • Use a spudger to disconnect the screen ribbon connector and free the display assembly.
      • The corners and edge of the LCD are fragile. Be careful attaching it to the back of the phone.
      • Carefully remove the screen from the device.
      Ask FixBot
    1. Nokia 6 Home Button Assembly Replacement, Home Button Assembly: step 9, image 1 of 1
      • Disconnect the battery connector with a spudger.
      Ask FixBot
    2. Nokia 6 Home Button Assembly Replacement: step 10, image 1 of 2 Nokia 6 Home Button Assembly Replacement: step 10, image 2 of 2
      Tool used on this step:
      Buy
      • Use a Phillips #00 screwdriver to remove the 1.2 mm x 2.2 mm screw in the upper hand corner of the phone.
      • Use tweezers to remove the bracket.
      Ask FixBot
    3. Nokia 6 Home Button Assembly Replacement: step 11, image 1 of 2 Nokia 6 Home Button Assembly Replacement: step 11, image 2 of 2
      • Detach the cable with the black nylon spudger.
      • Detach the home button and remove it from the device.
      Ask FixBot
Author
with
Chrissy Robins
1,603 Reputation
10 Guides authored
Cal Poly, Team S9-G15, Maness Spring 2019 Member of Cal Poly, Team S9-G15, Maness Spring 2019
CPSU-MANESS-S19S9G15
4 Members
120 Guides authored
1 Guide Comment
I am very grateful for your help,now I got it all figured out..I can do it own my own without necessary taking it to the Nokia center right here in Kenya. friday night funkin mods online
Britt Isaacs - Reply Share
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 70
All Time: 3,681
