Up to 20% off select tools
Nokia 6 Display Assembly Replacement
Views: 8.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
85
All Time:
8,198
Comments: 7
5 comments on steps, 2 guide comments.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Is your screen cracked? Is the touchscreen not working? Use this guide to restore your Nokia 6 screen back to working order. Before attempting this guide, please make sure that the phone is turned off as you will be opening the phone and disconnecting the screen from the phone’s main board.
    1. Nokia 6 Display Assembly Replacement, Display Assembly: step 1, image 1 of 3 Nokia 6 Display Assembly Replacement, Display Assembly: step 1, image 2 of 3 Nokia 6 Display Assembly Replacement, Display Assembly: step 1, image 3 of 3
      • Power off your Nokia 6 before beginning disassembly.
      • Insert the SIM card ejection tool into the hole on the left side of the phone.
      • Remove the SIM card and microSD card.
      Ask FixBot
    2. Nokia 6 Display Assembly Replacement: step 2, image 1 of 1
      • If your display glass is cracked, take precaution by taping over the display to prevent further breakage and harm.
      • Lay overlapping strips of clear packing tape over the Nokia 6's display until the whole screen is covered.
      Ask FixBot
    3. Nokia 6 Display Assembly Replacement: step 3, image 1 of 1
      • To soften the adhesive, use a heat gun and heat one edge of the phone for five minutes.
      • To use the heat gun, plug it into an outlet.
      • When the heat gun is plugged in, the heat gun automatically turns on and will start blowing hot air.
      Ask FixBot
    4. Nokia 6 Display Assembly Replacement: step 4, image 1 of 1
      • Take a Jimmy and slide it under the glass after the adhesive has been softened.
      • Place a pick under the glass after lifting with the pry tool so that the screen won't re-adhere to the frame again.
      • Make sure to not touch the LCD edge underneath the glass layer with the metal pry tool or the cards. This can damage the ribbon cables underneath and compromise the structural integrity of the phone itself.
      • The corners of the screen are the most fragile part of the screen. Make sure that the entire edge of the screen is dislodged from the frame before prying at the corners.
      Ask FixBot
    5. Nokia 6 Display Assembly Replacement: step 5, image 1 of 1
      • Lift the screen off of the phone.
      Ask FixBot
    6. Nokia 6 Display Assembly Replacement: step 6, image 1 of 2 Nokia 6 Display Assembly Replacement: step 6, image 2 of 2
      • Use a Phillips #000 screwdriver to remove the 1 mm x 1.4 mm screw holding down the metal bracket over the screen ribbon connector.
      Ask FixBot
    7. Nokia 6 Display Assembly Replacement: step 7, image 1 of 1
      • Remove the metal bracket with a tweezer.
      Ask FixBot
    8. Nokia 6 Display Assembly Replacement: step 8, image 1 of 1
      • Use a spudger to disconnect the screen ribbon connector and free the display assembly.
      • The corners and edge of the LCD are fragile. Be careful attaching it to the back of the phone.
      • Carefully remove the screen from the device.
      Ask FixBot
8 other people completed this guide.
Author
with
Chrissy Robins
1,603 Reputation
10 Guides authored
Cal Poly, Team S9-G15, Maness Spring 2019 Member of Cal Poly, Team S9-G15, Maness Spring 2019
CPSU-MANESS-S19S9G15
4 Members
120 Guides authored
2 Guide Comments
completed the guide. thx. my iphone claimed the screen is not original. anyway, seems to work correct. io games online
Soo Espinal - Reply Share
I want original display for nokia 6 mobile
SURIBABU SARAKANAM - Reply Share
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 85
All Time: 8,198
