Nokia 5165 Motherboard Replacement
    1. Nokia 5165 Motherboard Replacement, Removing The Battery: step 1, image 1 of 3 Nokia 5165 Motherboard Replacement, Removing The Battery: step 1, image 2 of 3 Nokia 5165 Motherboard Replacement, Removing The Battery: step 1, image 3 of 3
      • Remove the battery by pushing the button and sliding the battery out a bit then pulling it out
      Ask FixBot
    2. Nokia 5165 Motherboard Replacement, Removing The Front Cover: step 2, image 1 of 2 Nokia 5165 Motherboard Replacement, Removing The Front Cover: step 2, image 2 of 2
      • Find the tab at the top of the phone and press down with your fingernail or the flat end of a spudger
      • The top of the cover should pop out and then pull the top part out and the whole thing should come off
      Ask FixBot
    3. Nokia 5165 Motherboard Replacement, Removing The Motherboard: step 3, image 1 of 3 Nokia 5165 Motherboard Replacement, Removing The Motherboard: step 3, image 2 of 3 Nokia 5165 Motherboard Replacement, Removing The Motherboard: step 3, image 3 of 3
      • Remove these screws
      • 4 T6 Torx Screws
      • Lift up the white cover
      Ask FixBot
    4. Nokia 5165 Motherboard Replacement: step 4, image 1 of 2 Nokia 5165 Motherboard Replacement: step 4, image 2 of 2
      • 2 T6 Torx screws
      • Lift up the screen and number pad assembly
      Ask FixBot
    5. Nokia 5165 Motherboard Replacement: step 5, image 1 of 1
      • Pull out the motherboard
      Ask FixBot
Ethan Pikscher
351 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 27
All Time: 494
