Up to 20% off select tools
Nokia 3360 Battery Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
99
All Time:
3,263
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 minutes
Difficulty: Very easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
Changing the Battery is easy -- no tools required.
    1. Nokia 3360 Battery Replacement, Battery: step 1, image 1 of 1
      • Press down on the back of the phone with your thumb. Then slide the back plate upward toward the top of the phone.
      • Lift the back plate off the phone.
      Ask FixBot
    2. Nokia 3360 Battery Replacement: step 2, image 1 of 2 Nokia 3360 Battery Replacement: step 2, image 2 of 2
      • To release the battery, press the two tabs that are located directly above the battery towards the top of the phone at the same time.
      Ask FixBot
    3. Nokia 3360 Battery Replacement: step 3, image 1 of 2 Nokia 3360 Battery Replacement: step 3, image 2 of 2
      • Lift the battery out of the phone.
      • Note: Upon reassembly of the phone refer to second picture. The bottom of the battery with three square openings should line up with the prongs sticking out of the phone.
      Ask FixBot
2 other people completed this guide.
Author
with
Travis Malmgren
69 Reputation
2 Guides authored
Cal Poly, Team 8-39, Regan Winter 2010 Member of Cal Poly, Team 8-39, Regan Winter 2010
CPSU-REGAN-W10S8G39
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 99
All Time: 3,263
