Nokia 3310 3G Outer Frame Replacement
    1. Nokia 3310 3G Outer Frame Replacement, Battery: step 1, image 1 of 2 Nokia 3310 3G Outer Frame Replacement, Battery: step 1, image 2 of 2
      • Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
      Ask FixBot
    2. Nokia 3310 3G Outer Frame Replacement: step 2, image 1 of 2 Nokia 3310 3G Outer Frame Replacement: step 2, image 2 of 2
      • There is a molded notch in the white frame of the phone near the top right of the battery. Using either a finger or a plastic opening tool, utilize the notch to lift up on the battery, and remove it from the device.
      • This specific device did not come with a battery.
      Ask FixBot
    1. Nokia 3310 3G Outer Frame Replacement, Frame: step 3, image 1 of 3 Nokia 3310 3G Outer Frame Replacement, Frame: step 3, image 2 of 3 Nokia 3310 3G Outer Frame Replacement, Frame: step 3, image 3 of 3
      • Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
      • Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
      Ask FixBot
    1. Nokia 3310 3G Outer Frame Replacement, Motherboard: step 4, image 1 of 3 Nokia 3310 3G Outer Frame Replacement, Motherboard: step 4, image 2 of 3 Nokia 3310 3G Outer Frame Replacement, Motherboard: step 4, image 3 of 3
      • Use a spudger to simultaneously leverage the shell away and the motherboard up from the body of the shell.
      Ask FixBot
    1. Nokia 3310 3G Outer Frame Replacement, Speaker: step 5, image 1 of 2 Nokia 3310 3G Outer Frame Replacement, Speaker: step 5, image 2 of 2
      • Using a metal spudger, lodge the tip underneath the speaker and between the soft foam surrounding the screen.
      • Use the metal spudger to leverage out the speaker.
      • The speaker is attached to the shell with an adhesive. Do not be too aggressive in your removal, else the speaker will come apart.
      Ask FixBot
    1. Nokia 3310 3G Outer Frame Replacement, Outer Frame: step 6, image 1 of 1
      • Using your finger, push the keyboard insert out of the front outer frame.
      Ask FixBot
7 other people completed this guide.
Aaron LeBlanc
753 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 39
All Time: 1,532
