Nokia 3310 3G Motherboard Replacement
  1. Nokia 3310 3G Motherboard Replacement, Battery: step 1, image 1 of 2 Nokia 3310 3G Motherboard Replacement, Battery: step 1, image 2 of 2
    • Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
  2. Nokia 3310 3G Motherboard Replacement: step 2, image 1 of 2 Nokia 3310 3G Motherboard Replacement: step 2, image 2 of 2
    • There is a molded notch in the white frame of the phone near the top right of the battery. Using either a finger or a plastic opening tool, utilize the notch to lift up on the battery, and remove it from the device.
    • This specific device did not come with a battery.
  3. Nokia 3310 3G Motherboard Replacement, Frame: step 3, image 1 of 3 Nokia 3310 3G Motherboard Replacement, Frame: step 3, image 2 of 3 Nokia 3310 3G Motherboard Replacement, Frame: step 3, image 3 of 3
    • Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
    • Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
  4. Nokia 3310 3G Motherboard Replacement, Motherboard: step 4, image 1 of 3 Nokia 3310 3G Motherboard Replacement, Motherboard: step 4, image 2 of 3 Nokia 3310 3G Motherboard Replacement, Motherboard: step 4, image 3 of 3
    • Use a spudger to simultaneously leverage the shell away and the motherboard up from the body of the shell.
8 other people completed this guide.
Aaron LeBlanc
753 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 80
All Time: 2,294
