Nokia 3310 3G Keyboard Replacement
    1. Nokia 3310 3G Keyboard Replacement, Battery: step 1, image 1 of 2 Nokia 3310 3G Keyboard Replacement, Battery: step 1, image 2 of 2
      • Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
      Ask FixBot
    2. Nokia 3310 3G Keyboard Replacement: step 2, image 1 of 2 Nokia 3310 3G Keyboard Replacement: step 2, image 2 of 2
      • There is a molded notch in the white frame of the phone near the top right of the battery. Using either a finger or a plastic opening tool, utilize the notch to lift up on the battery, and remove it from the device.
      • This specific device did not come with a battery.
      Ask FixBot
    1. Nokia 3310 3G Keyboard Replacement, Frame: step 3, image 1 of 3 Nokia 3310 3G Keyboard Replacement, Frame: step 3, image 2 of 3 Nokia 3310 3G Keyboard Replacement, Frame: step 3, image 3 of 3
      • Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
      • Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
      Ask FixBot
    1. Nokia 3310 3G Keyboard Replacement, Motherboard: step 4, image 1 of 3 Nokia 3310 3G Keyboard Replacement, Motherboard: step 4, image 2 of 3 Nokia 3310 3G Keyboard Replacement, Motherboard: step 4, image 3 of 3
      • Use a spudger to simultaneously leverage the shell away and the motherboard up from the body of the shell.
      Ask FixBot
    1. Nokia 3310 3G Keyboard Replacement, Keyboard: step 5, image 1 of 3 Nokia 3310 3G Keyboard Replacement, Keyboard: step 5, image 2 of 3 Nokia 3310 3G Keyboard Replacement, Keyboard: step 5, image 3 of 3
      • Using a spudger, unclip the bottom left snap to unplug the keyboard. The image shows the motherboard rotated 90 degrees counterclockwise
      Ask FixBot
    2. Nokia 3310 3G Keyboard Replacement: step 6, image 1 of 1
      • Using your thumb, push the tab on the right side of the motherboard over to the right and then push downward to unclip the keyboard. It should fall away.
      Ask FixBot
5 other people completed this guide.
Aaron LeBlanc
753 Reputation
5 Guides authored
1 Guide Comment
Very useful and to the point
OrangeShoe - Reply Share
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 58
All Time: 3,375
