Up to 20% off select tools
Nokia 3310 3G Frame Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
13
Past 30 Days:
66
All Time:
1,510
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide walks through the removal of the plastic frame of the phone. Removal of this provides access to the motherboard and most other components.
    1. Nokia 3310 3G Frame Replacement, Battery: step 1, image 1 of 2 Nokia 3310 3G Frame Replacement, Battery: step 1, image 2 of 2
      • Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
      Ask FixBot
    2. Nokia 3310 3G Frame Replacement: step 2, image 1 of 2 Nokia 3310 3G Frame Replacement: step 2, image 2 of 2
      • There is a molded notch in the white frame of the phone near the top right of the battery. Using either a finger or a plastic opening tool, utilize the notch to lift up on the battery, and remove it from the device.
      • This specific device did not come with a battery.
      Ask FixBot
    1. Nokia 3310 3G Frame Replacement, Frame: step 3, image 1 of 3 Nokia 3310 3G Frame Replacement, Frame: step 3, image 2 of 3 Nokia 3310 3G Frame Replacement, Frame: step 3, image 3 of 3
      • Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
      • Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
      Ask FixBot
Author
with
Taylor Lyford
732 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 13
Past 30 Days: 66
All Time: 1,510
