Up to 20% off select tools
Nokia 3300B Screen Replacement
Views: 3.9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
14
Past 30 Days:
96
All Time:
3,940
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Tools
Introduction
Go to step 1 ↓
Describes how to replace the screen of the Nokia 3300B.
    1. Nokia 3300B Screen Replacement, Battery: step 1, image 1 of 2 Nokia 3300B Screen Replacement, Battery: step 1, image 2 of 2
      • Flip the Nokia 3300B over with the back-side facing towards you.
      • Gently press the button on the back of the battery cover to release the cover and slide up.
      Ask FixBot
    2. Nokia 3300B Screen Replacement: step 2, image 1 of 2 Nokia 3300B Screen Replacement: step 2, image 2 of 2
      • Lift the battery out of the back of the phone.
      • It is easiest to lift the battery out of the phone from the right-hand side, as seen in the picture.
      Ask FixBot
    1. Nokia 3300B Screen Replacement, Screen: step 3, image 1 of 3 Nokia 3300B Screen Replacement, Screen: step 3, image 2 of 3 Nokia 3300B Screen Replacement, Screen: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Gently push the blue tabs on the top of the phone out of their slots.
      • With the phone facing up, pop the blue faceplate off by using your fingernail (or some tweezers) and working your way around the phone.
      • Note: If the blue cover does not detach easily use your finger nails to try and split it open, as seen in the picture.
      Ask FixBot
    2. Nokia 3300B Screen Replacement: step 4, image 1 of 1
      • With the screen still facing you, remove the blue faceplate.
      Ask FixBot
    3. Nokia 3300B Screen Replacement: step 5, image 1 of 2 Nokia 3300B Screen Replacement: step 5, image 2 of 2
      • Grab the sides of the keypad and lift it up vertically.
      • If you encounter resistance while removing the keypad, be sure to lift up evenly on both sides, so the button's pin don't snap.
      Ask FixBot
    4. Nokia 3300B Screen Replacement: step 6, image 1 of 3 Nokia 3300B Screen Replacement: step 6, image 2 of 3 Nokia 3300B Screen Replacement: step 6, image 3 of 3
      • Using the Torx T6 bit of a Phillips precision screwdriver, remove the six screws on the phone's inner protective case, as seen in the picture.
      • NOTE: Be sure to save these screws so the phone can be reassembled later.
      Ask FixBot
    5. Nokia 3300B Screen Replacement: step 7, image 1 of 2 Nokia 3300B Screen Replacement: step 7, image 2 of 2
      • Holding the phone with the screen facing you, remove the top half of the phone from the circuit board.
      Ask FixBot
    6. Nokia 3300B Screen Replacement: step 8, image 1 of 3 Nokia 3300B Screen Replacement: step 8, image 2 of 3 Nokia 3300B Screen Replacement: step 8, image 3 of 3
      • Hold the top half of the phone with the screen facing you.
      • Using a pair of tweezers, release the tabs holding the two distinct cases together.
      • The tabs are very fragile. Be gentle when releasing the tabs.
      Ask FixBot
    7. Nokia 3300B Screen Replacement: step 9, image 1 of 1
      • Be sure to remove both casings so that the screen is facing down. This will ensure that the screen does not fall out of its case.
      • NOTE: The screen's part identification sticker is on the top back side of the screen. The screen will need to be replaced with the same orientation.
      Ask FixBot
    8. Nokia 3300B Screen Replacement: step 10, image 1 of 1
      • Tilt the casing back and the screen should fall out smoothly.
      • Replace the old screen with the new screen.
      Ask FixBot
2 other people completed this guide.
Author
with
Chris Colwell
116 Reputation
2 Guides authored
Cal Poly, Team 18-65, Johann Spring 2010 Member of Cal Poly, Team 18-65, Johann Spring 2010
CPSU-JOHANN-S10S18G65
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 96
All Time: 3,940
