Nokia 3300B Motherboard Replacement
Views: 3.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
83
All Time:
3,533
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
To change or clean the logic board the phone must be dissembled. The tools required will be a T-6 screw driver.
Tools
    1. Nokia 3300B Motherboard Replacement, Battery: step 1, image 1 of 2 Nokia 3300B Motherboard Replacement, Battery: step 1, image 2 of 2
      • Flip the Nokia 3300B over with the back-side facing towards you.
      • Gently press the button on the back of the battery cover to release the cover and slide up.
      Ask FixBot
    2. Nokia 3300B Motherboard Replacement: step 2, image 1 of 2 Nokia 3300B Motherboard Replacement: step 2, image 2 of 2
      • Lift the battery out of the back of the phone.
      • It is easiest to lift the battery out of the phone from the right-hand side, as seen in the picture.
      Ask FixBot
    1. Nokia 3300B Motherboard Replacement, Keyboard: step 3, image 1 of 2 Nokia 3300B Motherboard Replacement, Keyboard: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Gently push the blue tabs on the top of the phone out of their slots.
      • With the phone facing up, pop the blue faceplate off by using your fingernail (or some tweezers) and working your way around the phone.
      • Note: If the blue cover does not detach easily use your finger nails to try and split it open, as seen in the picture.
      Ask FixBot
    2. Nokia 3300B Motherboard Replacement: step 4, image 1 of 1
      • With the screen still facing you, lift and remove the blue faceplate.
      Ask FixBot
    3. Nokia 3300B Motherboard Replacement: step 5, image 1 of 1
      • Grab the sides of the keypad and lift each side up vertically, until the keypad is completely removed.
      • If you encounter resistance while removing the keypad, be sure to lift up evenly on both sides to ensure that the pins do not snap.
      • When replacing the keypad, make sure that the plastic pegs all enter their proper holes.
      Ask FixBot
    1. Nokia 3300B Motherboard Replacement, Motherboard: step 6, image 1 of 2 Nokia 3300B Motherboard Replacement, Motherboard: step 6, image 2 of 2
      • Remove the six Torx T6 screws from the phone's front case.
      Ask FixBot
    2. Nokia 3300B Motherboard Replacement: step 7, image 1 of 1
      • Pull up on the front case containing the screen to separate it from the rest of the phone.
      • Gently lift the main board out of the back case.
      Ask FixBot
4 other people completed this guide.
Jose Quezada
59 Reputation
1 Guide authored
Cal Poly, Team 18-65, Johann Spring 2010 Member of Cal Poly, Team 18-65, Johann Spring 2010
CPSU-JOHANN-S10S18G65
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 83
All Time: 3,533
