Nokia 3120 Speaker Replacement
  1. Nokia 3120 Speaker Replacement, Battery Installation: step 1, image 1 of 3 Nokia 3120 Speaker Replacement, Battery Installation: step 1, image 2 of 3 Nokia 3120 Speaker Replacement, Battery Installation: step 1, image 3 of 3
    • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
    Ask FixBot
  2. Nokia 3120 Speaker Replacement: step 2, image 1 of 1
    • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
    Ask FixBot
  3. Nokia 3120 Speaker Replacement, Face Plate: step 3, image 1 of 3 Nokia 3120 Speaker Replacement, Face Plate: step 3, image 2 of 3 Nokia 3120 Speaker Replacement, Face Plate: step 3, image 3 of 3
    • Using your fingernails or another tool, pry the front face plate out along its edges and corners.
    Ask FixBot
  4. Nokia 3120 Speaker Replacement, Speaker: step 4, image 1 of 2 Nokia 3120 Speaker Replacement, Speaker: step 4, image 2 of 2
    • Once the cover plate has been removed, the existing keypad should be easily removed.
    Ask FixBot
  5. Nokia 3120 Speaker Replacement: step 5, image 1 of 2 Nokia 3120 Speaker Replacement: step 5, image 2 of 2
    • Once the keypad has been removed, unscrew the 6 exposed screws on the front of the phone.
    Ask FixBot
  6. Nokia 3120 Speaker Replacement: step 6, image 1 of 1
    • Once all the screws have been removed, the front part of the phone should be removable from the rest of the phone.
    Ask FixBot
  7. Nokia 3120 Speaker Replacement: step 7, image 1 of 1
    • To remove the speaker from the phone, take a pencil or sharp object and poke the speaker free from the removed front part of the phone.
    • To install a new speaker, simply place a new speaker in the same location and put the phone back together.
    Ask FixBot
Pierre Tong
92 Reputation
4 Guides authored
Clemson, Team 13-2, Benson Spring 2013 Member of Clemson, Team 13-2, Benson Spring 2013
CLEM-BENSON-S13S13G2
3 Members
23 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 43
All Time: 1,690
