Nokia 3120 Liquid Crystal Display (LCD) Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
98
All Time:
2,110
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
The LCD is difficult to get to and the guide requires a moderate amount of work. Tiny parts require patience during disassembly.
Tools
    1. Nokia 3120 Liquid Crystal Display (LCD) Replacement, Battery Installation: step 1, image 1 of 3 Nokia 3120 Liquid Crystal Display (LCD) Replacement, Battery Installation: step 1, image 2 of 3 Nokia 3120 Liquid Crystal Display (LCD) Replacement, Battery Installation: step 1, image 3 of 3
      • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
      Ask FixBot
    2. Nokia 3120 Liquid Crystal Display (LCD) Replacement: step 2, image 1 of 1
      • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
      Ask FixBot
    1. Nokia 3120 Liquid Crystal Display (LCD) Replacement, Face Plate: step 3, image 1 of 3 Nokia 3120 Liquid Crystal Display (LCD) Replacement, Face Plate: step 3, image 2 of 3 Nokia 3120 Liquid Crystal Display (LCD) Replacement, Face Plate: step 3, image 3 of 3
      • Using your fingernails or another tool, pry the front face plate out along its edges and corners.
      Ask FixBot
    1. Nokia 3120 Liquid Crystal Display (LCD) Replacement, Liquid Crystal Display (LCD): step 4, image 1 of 1
      • Once the cover plate has been removed, the keypad should easily pop out.
      Ask FixBot
    2. Nokia 3120 Liquid Crystal Display (LCD) Replacement: step 5, image 1 of 2 Nokia 3120 Liquid Crystal Display (LCD) Replacement: step 5, image 2 of 2
      • Using a screwdriver, remove the 6, 7 mm Torx-head screws on the front of the phone.
      Ask FixBot
    3. Nokia 3120 Liquid Crystal Display (LCD) Replacement: step 6, image 1 of 1
      • Once the screws have been removed, the front plate of the phone should be removed, exposing the inside electronic components of the phone.
      Ask FixBot
    4. Nokia 3120 Liquid Crystal Display (LCD) Replacement: step 7, image 1 of 1
      • Take out the cell phone electronic board
      Ask FixBot
    5. Nokia 3120 Liquid Crystal Display (LCD) Replacement: step 8, image 1 of 1
      • The LCD screen can now be removed from the body of the phone.
      Ask FixBot
2 other people completed this guide.
Pierre Tong
92 Reputation
4 Guides authored
Clemson, Team 13-2, Benson Spring 2013 Member of Clemson, Team 13-2, Benson Spring 2013
CLEM-BENSON-S13S13G2
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 98
All Time: 2,110
