Nokia 3.1 Display Assembly Replacement
  1. Nokia 3.1 Display Assembly Replacement, Battery: step 1, image 1 of 1
    • First, remove the SIM and SD card trays.
  2. Nokia 3.1 Display Assembly Replacement, Open the back cover: step 2, image 1 of 3 Nokia 3.1 Display Assembly Replacement, Open the back cover: step 2, image 2 of 3 Nokia 3.1 Display Assembly Replacement, Open the back cover: step 2, image 3 of 3
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • Try to use a thin tool like a razor blade to start to pry open the back cover.
    • When you opened it up just a little bit put a plastic card or a plastic opening tool inside the gap.
    • Using the plastic tool slowly make your way around the back cover. You can also use a guitar pick or similar.
    • Hint: the back cover is attached to the body with several plastic noses as well as a thin strip of adhesive. The cover is quite flexible and sturdy.
  3. Nokia 3.1 Display Assembly Replacement, Remove logic board cover: step 3, image 1 of 2 Nokia 3.1 Display Assembly Replacement, Remove logic board cover: step 3, image 2 of 2
    • Remove the seven Torx T5 screws from the logic board cover.
    • Remove the logic board cover.
    • Lift up the battery connector from the logic board.
  4. Nokia 3.1 Display Assembly Replacement, Remove battery adhesive strips: step 4, image 1 of 2 Nokia 3.1 Display Assembly Replacement, Remove battery adhesive strips: step 4, image 2 of 2
    • At the bottom end of the battery you will see two black ends of adhesive strips showing up from underneath the battery.
    • Slowly pull at those adhesive strip ends to be able to lift out the battery.
  5. Nokia 3.1 Display Assembly Replacement, Remove logic board: step 5, image 1 of 2 Nokia 3.1 Display Assembly Replacement, Remove logic board: step 5, image 2 of 2
    • Remove of connectors from the logic board:
    • button connector,
    • display connector,
    • second board connector and
    • WIFI cable connector.
    • Now remove the logic board by slowly wiggling it up. There are no screws used to attached it to the case. Only an adhesive strip on its back holds it in place.
  6. Nokia 3.1 Display Assembly Replacement, Peal up display cable: step 6, image 1 of 1
    • Slowly peal up the display cable starting from the connector.
  7. Nokia 3.1 Display Assembly Replacement, Remove the display: step 7, image 1 of 2 Nokia 3.1 Display Assembly Replacement, Remove the display: step 7, image 2 of 2
    Plastic Cards
    $2.99
    Buy
    • Before trying to disassemble the display you need to heat it up to loosen the adhesive that holds it in place.
    • Hint: There is much less glue at the sides of the display compared to the top and bottom. So start on the sides to get under the display.
    • Use a flat tool like a razor blade to get under the display. Slowly loosen up the sides by cutting through the heated up adhesive.
    • Especially after getting under the display initially with the razor blade a slightly thicker tool like a plastic card might be worth a try. When loosening up the top and bottom of the display you will need patience and a plastic card won't damage the plastic frame as much.
  8. Nokia 3.1 Display Assembly Replacement, Clean the frame: step 8, image 1 of 2 Nokia 3.1 Display Assembly Replacement, Clean the frame: step 8, image 2 of 2
    • After removing the display you will need some isopropanol alcohol to clean the leftover adhesive.
To reassemble your device, follow these instructions in reverse order. You should use glue to attach the display assembly to the frame.
4 other people completed this guide.
Baschtl
1,664 Reputation
5 Guides authored
2 Guide Comments
My mobile get broken how much it cost for screen replacement
Aayan Bobe - Reply Share
The same way for Nokia 4.2?
Alfons Dekker - Reply Share
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 41
All Time: 4,752
