Nokia 3.1 Battery Replacement
  1. Nokia 3.1 Battery Replacement, Battery: step 1, image 1 of 1
    • First, remove the SIM and SD card trays.
  2. Nokia 3.1 Battery Replacement, Open the back cover: step 2, image 1 of 3 Nokia 3.1 Battery Replacement, Open the back cover: step 2, image 2 of 3 Nokia 3.1 Battery Replacement, Open the back cover: step 2, image 3 of 3
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • Try to use a thin tool like a razor blade to start to pry open the back cover.
    • When you opened it up just a little bit put a plastic card or a plastic opening tool inside the gap.
    • Using the plastic tool slowly make your way around the back cover. You can also use a guitar pick or similar.
    • Hint: the back cover is attached to the body with several plastic noses as well as a thin strip of adhesive. The cover is quite flexible and sturdy.
  3. Nokia 3.1 Battery Replacement, Remove logic board cover: step 3, image 1 of 2 Nokia 3.1 Battery Replacement, Remove logic board cover: step 3, image 2 of 2
    • Remove the seven Torx T5 screws from the logic board cover.
    • Remove the logic board cover.
    • Lift up the battery connector from the logic board.
  4. Nokia 3.1 Battery Replacement, Remove battery adhesive strips: step 4, image 1 of 2 Nokia 3.1 Battery Replacement, Remove battery adhesive strips: step 4, image 2 of 2
    • At the bottom end of the battery you will see two black ends of adhesive strips showing up from underneath the battery.
    • Slowly pull at those adhesive strip ends to be able to lift out the battery.
To reassemble your device, follow these instructions in reverse order. Also don’t forget some double-faced adhesive tape to fixate the new battery.
9 other people completed this guide.
Baschtl
1,664 Reputation
5 Guides authored
1 Guide Comment
Merci beaucoup
GEORGES Sylvestre - Reply Share
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 52
All Time: 8,321
