Nokia 2780 Flip Charging Port Replacement
  1. Nokia 2780 Flip Charging Port Replacement, Battery: step 1, image 1 of 1
    • Insert an iFixit opening tool into the seam between the back case and the bottom edge of the phone.
    • If possible, use a plastic prying tool instead of a metal one to reduce the risk of damaging delicate internal components like the battery or motherboard.
    Ask FixBot
  2. Nokia 2780 Flip Charging Port Replacement: step 2, image 1 of 1
    • Slide the opening tool or spudger around the edge of the phone to release the clips securing the bottom case.
    • Gently pry the bottom case from the phone to remove it.
    Ask FixBot
  3. Nokia 2780 Flip Charging Port Replacement: step 3, image 1 of 2 Nokia 2780 Flip Charging Port Replacement: step 3, image 2 of 2
    • Lift the battery up and out of the compartment.
    • Ensure the replacement battery is a “HE402 1450mAh 3.85V 5.58WH” Li-ion battery.
    Ask FixBot
  4. Nokia 2780 Flip Charging Port Replacement, Motherboard: step 4, image 1 of 2 Nokia 2780 Flip Charging Port Replacement, Motherboard: step 4, image 2 of 2
    • Use a Torx T5 screwdriver to remove the six visible 1.4 mm screws that secure the internal rear housing.
    Ask FixBot
  5. Nokia 2780 Flip Charging Port Replacement: step 5, image 1 of 2 Nokia 2780 Flip Charging Port Replacement: step 5, image 2 of 2
    • Insert a plastic opening tool in the seam between the top case and midframe and slide it around the perimeter to release the clips holding them together.
    • Remove the midframe from the phone.
    Ask FixBot
  6. Nokia 2780 Flip Charging Port Replacement: step 6, image 1 of 2 Nokia 2780 Flip Charging Port Replacement: step 6, image 2 of 2
    • Place a spudger or an opening tool under the edge of the press connector and pry straight up to disconnect it.
    • Make sure to pry under the edge of the connector itself, and not under the socket on the board. Otherwise, you risk permanently damaging the socket.
    • To reconnect, align the connector carefully over its socket and press down with your fingertip—first on one of the short sides, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
    Ask FixBot
  7. Nokia 2780 Flip Charging Port Replacement: step 7, image 1 of 2 Nokia 2780 Flip Charging Port Replacement: step 7, image 2 of 2
    • Remove the plastic cover on top of the hinge.
    Ask FixBot
  8. Nokia 2780 Flip Charging Port Replacement: step 8, image 1 of 3 Nokia 2780 Flip Charging Port Replacement: step 8, image 2 of 3 Nokia 2780 Flip Charging Port Replacement: step 8, image 3 of 3
    • Pull back the frame surrounding the motherboard from both sides and gently remove the motherboard.
    Ask FixBot
  9. Nokia 2780 Flip Charging Port Replacement, Charging Port: step 9, image 1 of 1
    • Locate the charging port connector on the motherboard.
    Ask FixBot
  10. Nokia 2780 Flip Charging Port Replacement: step 10, image 1 of 3 Nokia 2780 Flip Charging Port Replacement: step 10, image 2 of 3 Nokia 2780 Flip Charging Port Replacement: step 10, image 3 of 3
    • Use a soldering iron to desolder the solder joints on the back of the charging port.
    • Be very careful when using a soldering iron. It is extremely hot and can easily burn and even melt the board if handled improperly.
    • Although the photos show desoldering from the top of the board, the solder joints are more easily accessed from the back side of the board.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 34
All Time: 116
