Nokia 2780 Flip Battery Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
36
Past 30 Days:
109
All Time:
606
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 - 5 minutes
Difficulty: Very easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
Follow this guide to replace the battery in your Nokia 2780 Flip.
Over time, rechargeable lithium-ion batteries degrade naturally. This can lead to a shorter battery life, slower device performance, and unexpected shutdowns. Nokia batteries are rated to deliver up to 18 days of standby time and up to 7 hours of talk time on a single charge, lasting up to 2-3 years. If you notice your Nokia needs to be charged frequently, doesn't hold a charge, or is slow during use, it could be time to replace the battery to restore normal performance.
Before starting this repair, ensure the device is powered off and unplugged from any charging source.
 Caution: Be very careful when handling the battery, especially if it appears swollen or smells strange. A swollen battery can catch fire or explode. Follow the suggestions found in the What to do with a swollen battery wiki for helpful tips and safety information.
Tools
    1. Nokia 2780 Flip Battery Replacement, Battery: step 1, image 1 of 1
      • Insert an iFixit opening tool into the seam between the back case and the bottom edge of the phone.
      • If possible, use a plastic prying tool instead of a metal one to reduce the risk of damaging delicate internal components like the battery or motherboard.
      Ask FixBot
    2. Nokia 2780 Flip Battery Replacement: step 2, image 1 of 1
      • Slide the opening tool or spudger around the edge of the phone to release the clips securing the bottom case.
      • Gently pry the bottom case from the phone to remove it.
      Ask FixBot
    3. Nokia 2780 Flip Battery Replacement: step 3, image 1 of 2 Nokia 2780 Flip Battery Replacement: step 3, image 2 of 2
      • Lift the battery up and out of the compartment.
      • Ensure the replacement battery is a “HE402 1450mAh 3.85V 5.58WH” Li-ion battery.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 36
Past 30 Days: 109
All Time: 606
