Nokia 2660 Flip Motherboard Replacement
  1. Nokia 2660 Flip Motherboard Replacement, Battery: step 1, image 1 of 3 Nokia 2660 Flip Motherboard Replacement, Battery: step 1, image 2 of 3 Nokia 2660 Flip Motherboard Replacement, Battery: step 1, image 3 of 3
    • Turn your Nokia around to the rear side.
    • Insert a spudger or your fingernail into the notch on the bottom of the device.
    Ask FixBot
  2. Nokia 2660 Flip Motherboard Replacement: step 2, image 1 of 3 Nokia 2660 Flip Motherboard Replacement: step 2, image 2 of 3 Nokia 2660 Flip Motherboard Replacement: step 2, image 3 of 3
    • Pry the rear casing out towards you.
    Ask FixBot
  3. Nokia 2660 Flip Motherboard Replacement: step 3, image 1 of 3 Nokia 2660 Flip Motherboard Replacement: step 3, image 2 of 3 Nokia 2660 Flip Motherboard Replacement: step 3, image 3 of 3
    • Insert a spudger or fingernail into the slot.
    • Gently remove the battery out of the slot.
    • Keep in mind inserting the new battery into the prongs.
    Ask FixBot
  4. Nokia 2660 Flip Motherboard Replacement, Motherboard: step 4, image 1 of 3 Nokia 2660 Flip Motherboard Replacement, Motherboard: step 4, image 2 of 3 Nokia 2660 Flip Motherboard Replacement, Motherboard: step 4, image 3 of 3
    • Remove the screws using the TR6 Torx screwdriver.
    • Lift up the red casing with a spudger to reveal the motherboard.
    Ask FixBot
  5. Nokia 2660 Flip Motherboard Replacement: step 5, image 1 of 3 Nokia 2660 Flip Motherboard Replacement: step 5, image 2 of 3 Nokia 2660 Flip Motherboard Replacement: step 5, image 3 of 3
    • Be very gentle with the motherboard as pulling too harshly can damage the ribbon cable.
    • With a clean fingernail or spudger, detach the ribbon cable.
    • Use a Jimmy to lift the motherboard up and place it to the side.
    • Once the motherboard has been removed check for any damages, if there are any you must safely dispose of the motherboard itself.
    Ask FixBot
Kobe Rouke
521 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 46
All Time: 119
