Up to 20% off select tools
Nokia 2630b LCD Display Replacement
Views: 1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
94
All Time:
1,004
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 40 minutes - 1 hour
Difficulty: Easy
Community-Contributed Guide
Parts
Tools
    1. Nokia 2630b LCD Display Replacement, LCD Display: step 1, image 1 of 3 Nokia 2630b LCD Display Replacement, LCD Display: step 1, image 2 of 3 Nokia 2630b LCD Display Replacement, LCD Display: step 1, image 3 of 3
      • Remove the Back cover by Pressing the release buttons located on either side of the battery cover
      • Now Remove The Battery and Simcard from the slots
      Ask FixBot
    2. Nokia 2630b LCD Display Replacement: step 2, image 1 of 3 Nokia 2630b LCD Display Replacement: step 2, image 2 of 3 Nokia 2630b LCD Display Replacement: step 2, image 3 of 3
      • Remove the two screws on either side of the back side using the microscrewdriver using the T5 bit
      • Now Remove the Front key panel from the Main Board Carefully using the Plastic Opening Tools
      Ask FixBot
    3. Nokia 2630b LCD Display Replacement: step 3, image 1 of 3 Nokia 2630b LCD Display Replacement: step 3, image 2 of 3 Nokia 2630b LCD Display Replacement: step 3, image 3 of 3
      • Now Remove the four screws in the front side of the main board
      • Now push the Board from the Battery slot side and carefully By using the Plastic Opening Tools Separate the board from the back case or rear case
      Ask FixBot
    4. Nokia 2630b LCD Display Replacement: step 4, image 1 of 2 Nokia 2630b LCD Display Replacement: step 4, image 2 of 2
      • Now Gently Separate the lock at the right side to remove the outer cover of the Main Board
      • !!!! Be Cautious that the key panel is attached at the other end
      Ask FixBot
    5. Nokia 2630b LCD Display Replacement: step 5, image 1 of 3 Nokia 2630b LCD Display Replacement: step 5, image 2 of 3 Nokia 2630b LCD Display Replacement: step 5, image 3 of 3
      • Remove the Chip which is attached to the main board
      • Now we can separate the display from the main board and we can replace it with the new display.
      Ask FixBot
2 other people completed this guide.
Author
with
LOGESAM
123 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 94
All Time: 1,004
