Nokia 2610 Speaker Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
90
All Time:
3,292
Comments: 2
2 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 6 - 8 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
After you have successfully completed the faceplate and circuit board removal guide this guide will show you how to replace the speaker
Tools
    1. Nokia 2610 Speaker Replacement, Battery and Sim Card: step 1, image 1 of 3 Nokia 2610 Speaker Replacement, Battery and Sim Card: step 1, image 2 of 3 Nokia 2610 Speaker Replacement, Battery and Sim Card: step 1, image 3 of 3
      • Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
      Ask FixBot
    2. Nokia 2610 Speaker Replacement: step 2, image 1 of 3 Nokia 2610 Speaker Replacement: step 2, image 2 of 3 Nokia 2610 Speaker Replacement: step 2, image 3 of 3
      • Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
      Ask FixBot
    3. Nokia 2610 Speaker Replacement: step 3, image 1 of 3 Nokia 2610 Speaker Replacement: step 3, image 2 of 3 Nokia 2610 Speaker Replacement: step 3, image 3 of 3
      • Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger.
      • After removal, lower the metal sim card holder into its original position.
      Ask FixBot
    1. Nokia 2610 Speaker Replacement, Front Pannel: step 4, image 1 of 2 Nokia 2610 Speaker Replacement, Front Pannel: step 4, image 2 of 2
      • Insert the plastic opening tool into the crack between the front and back panels.
      • Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
      Ask FixBot
    2. Nokia 2610 Speaker Replacement: step 5, image 1 of 2 Nokia 2610 Speaker Replacement: step 5, image 2 of 2
      • Lift the bottom of the front cover away from the phone.
      • Continue lifting until the top of the front cover is fully removed from the phone.
      • Note: To replace the Keypad, gently lift it out of the front cover. It is located below the clear viewing window.
      Ask FixBot
    1. Nokia 2610 Speaker Replacement, Circuit Board: step 6, image 1 of 1
      • Use the Torx screwdriver with the T6 attachmet to remove the 6 .4 mm screws around the outside of the circuit board.
      • Note: Removing the 4 T6 screws around the screen will loosen it, so don't worry if the screen also separates from the circuit board.
      Ask FixBot
    2. Nokia 2610 Speaker Replacement: step 7, image 1 of 3 Nokia 2610 Speaker Replacement: step 7, image 2 of 3 Nokia 2610 Speaker Replacement: step 7, image 3 of 3
      • Lift the circuit board out of the back cover.
      Ask FixBot
    1. Nokia 2610 Speaker Replacement, Speaker: step 8, image 1 of 3 Nokia 2610 Speaker Replacement, Speaker: step 8, image 2 of 3 Nokia 2610 Speaker Replacement, Speaker: step 8, image 3 of 3
      • Using the plastic opening tool, gently pry the speaker out of its slot in the back cover of the phone.
      • Note: The easiest way to remove the speaker is to insert the plastic opening tool in the upper right corner of the speaker.
      Ask FixBot
2 other people completed this guide.
Taylor Hinsdale
93 Reputation
2 Guides authored
Cal Poly, Team 7-52, Amido Fall 2010 Member of Cal Poly, Team 7-52, Amido Fall 2010
CPSU-AMIDO-F10S7G52
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 90
All Time: 3,292
