Nokia 225 4G 2020 Motherboard Replacement
  1. Nokia 225 4G 2020 Motherboard Replacement, Battery: step 1, image 1 of 3 Nokia 225 4G 2020 Motherboard Replacement, Battery: step 1, image 2 of 3 Nokia 225 4G 2020 Motherboard Replacement, Battery: step 1, image 3 of 3
    • Insert an iFixit opening pick into the seam along the bottom edge of the phone’s back cover.
    • Slide the pick around the edges of the cover to release the retaining clips.
    • Remove the back casing to expose the battery.
    Ask FixBot
  2. Nokia 225 4G 2020 Motherboard Replacement: step 2, image 1 of 3 Nokia 225 4G 2020 Motherboard Replacement: step 2, image 2 of 3 Nokia 225 4G 2020 Motherboard Replacement: step 2, image 3 of 3
    • Remove the battery by lifting it from the edge near the microSD card slot.
    • Install the battery, ensuring the metal contacts align with the connector at the bottom right of the compartment.
    Ask FixBot
  3. Nokia 225 4G 2020 Motherboard Replacement, Motherboard: step 3, image 1 of 2 Nokia 225 4G 2020 Motherboard Replacement, Motherboard: step 3, image 2 of 2
    • Use a T3 Torx screwdriver to remove the six screws along the edge of the bottom cover.
    Ask FixBot
  4. Nokia 225 4G 2020 Motherboard Replacement: step 4, image 1 of 3 Nokia 225 4G 2020 Motherboard Replacement: step 4, image 2 of 3 Nokia 225 4G 2020 Motherboard Replacement: step 4, image 3 of 3
    • Insert an iFixit opening tool into the seam between the display and midframe and slide it around the edges to release the retaining clips.
    • Hold the device on both sides, then separate the display and the midframe to expose the motherboard.
    • Remove the motherboard.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Whitley O.
521 Reputation
5 Guides authored
Texas Tech, Team 11-3, Weston Spring 2026 Member of Texas Tech, Team 11-3, Weston Spring 2026
TTU-WESTON-S26S11G3
5 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 39
All Time: 184
