Up to 20% off select tools
Nokia 2128i Power Button Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
5
Past 7 Days:
16
Past 30 Days:
89
All Time:
2,448
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If the power button is broken or does not press properly, replace the small plastic button.
    1. Nokia 2128i Power Button Replacement, Battery: step 1, image 1 of 3 Nokia 2128i Power Button Replacement, Battery: step 1, image 2 of 3 Nokia 2128i Power Button Replacement, Battery: step 1, image 3 of 3
      • Be sure cell phone is off before you begin to disassemble the phone.
      • Press the button on the bottom of the back of the cell phone.
      • Slide rear panel down and remove it.
      Ask FixBot
    2. Nokia 2128i Power Button Replacement: step 2, image 1 of 3 Nokia 2128i Power Button Replacement: step 2, image 2 of 3 Nokia 2128i Power Button Replacement: step 2, image 3 of 3
      • Using your fingernail, pry the back of the battery upwards and pull out.
      Ask FixBot
    1. Nokia 2128i Power Button Replacement, Faceplate: step 3, image 1 of 3 Nokia 2128i Power Button Replacement, Faceplate: step 3, image 2 of 3 Nokia 2128i Power Button Replacement, Faceplate: step 3, image 3 of 3
      • Insert the plastic opening tool under the faceplate.
      • Separate the faceplate from main body by twisting the prying tool with some force.
      • The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
      Ask FixBot
    1. Nokia 2128i Power Button Replacement, Keypad: step 4, image 1 of 3 Nokia 2128i Power Button Replacement, Keypad: step 4, image 2 of 3 Nokia 2128i Power Button Replacement, Keypad: step 4, image 3 of 3
      • With the faceplate removed, simply peel off rubber key pad and remove.
      Ask FixBot
    1. Nokia 2128i Power Button Replacement, Motherboard Assembly: step 5, image 1 of 3 Nokia 2128i Power Button Replacement, Motherboard Assembly: step 5, image 2 of 3 Nokia 2128i Power Button Replacement, Motherboard Assembly: step 5, image 3 of 3
      • Locate and remove the six screws on the front of the phone using a T6 Torx.
      • All 6 screws are 6.9mm long.
      Ask FixBot
    2. Nokia 2128i Power Button Replacement: step 6, image 1 of 3 Nokia 2128i Power Button Replacement: step 6, image 2 of 3 Nokia 2128i Power Button Replacement: step 6, image 3 of 3
      • After removing screws, lift the motherboard assembly straight off the cell phone body.
      Ask FixBot
    1. Nokia 2128i Power Button Replacement, Power Button: step 7, image 1 of 3 Nokia 2128i Power Button Replacement, Power Button: step 7, image 2 of 3 Nokia 2128i Power Button Replacement, Power Button: step 7, image 3 of 3
      • With the motherboard and LCD unit removed, gently pull the power button out of its housing.
      Ask FixBot
Author
with
Curtis Lutje
43 Reputation
6 Guides authored
Cal Poly, Team 20-8, Maness Fall 2010 Member of Cal Poly, Team 20-8, Maness Fall 2010
CPSU-MANESS-F10S20G8
4 Members
144 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 16
Past 30 Days: 89
All Time: 2,448
