Nokia 2128i Logic Board Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
5
Past 30 Days:
33
All Time:
1,750
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If the phone's problem lies in the logic board, use this guide to change the logic board out.
Tools
    1. Nokia 2128i Logic Board Replacement, Battery: step 1, image 1 of 3 Nokia 2128i Logic Board Replacement, Battery: step 1, image 2 of 3 Nokia 2128i Logic Board Replacement, Battery: step 1, image 3 of 3
      • Be sure cell phone is off before you begin to disassemble the phone.
      • Press the button on the bottom of the back of the cell phone.
      • Slide rear panel down and remove it.
      Ask FixBot
    2. Nokia 2128i Logic Board Replacement: step 2, image 1 of 3 Nokia 2128i Logic Board Replacement: step 2, image 2 of 3 Nokia 2128i Logic Board Replacement: step 2, image 3 of 3
      • Using your fingernail, pry the back of the battery upwards and pull out.
      Ask FixBot
    1. Nokia 2128i Logic Board Replacement, Faceplate: step 3, image 1 of 3 Nokia 2128i Logic Board Replacement, Faceplate: step 3, image 2 of 3 Nokia 2128i Logic Board Replacement, Faceplate: step 3, image 3 of 3
      • Insert the plastic opening tool under the faceplate.
      • Separate the faceplate from main body by twisting the prying tool with some force.
      • The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
      Ask FixBot
    1. Nokia 2128i Logic Board Replacement, Keypad: step 4, image 1 of 3 Nokia 2128i Logic Board Replacement, Keypad: step 4, image 2 of 3 Nokia 2128i Logic Board Replacement, Keypad: step 4, image 3 of 3
      • With the faceplate removed, simply peel off rubber key pad and remove.
      Ask FixBot
    1. Nokia 2128i Logic Board Replacement, Motherboard Assembly: step 5, image 1 of 3 Nokia 2128i Logic Board Replacement, Motherboard Assembly: step 5, image 2 of 3 Nokia 2128i Logic Board Replacement, Motherboard Assembly: step 5, image 3 of 3
      • Locate and remove the six screws on the front of the phone using a T6 Torx.
      • All 6 screws are 6.9mm long.
      Ask FixBot
    2. Nokia 2128i Logic Board Replacement: step 6, image 1 of 3 Nokia 2128i Logic Board Replacement: step 6, image 2 of 3 Nokia 2128i Logic Board Replacement: step 6, image 3 of 3
      • After removing screws, lift the motherboard assembly straight off the cell phone body.
      Ask FixBot
    1. Nokia 2128i Logic Board Replacement, Logic Board: step 7, image 1 of 3 Nokia 2128i Logic Board Replacement, Logic Board: step 7, image 2 of 3 Nokia 2128i Logic Board Replacement, Logic Board: step 7, image 3 of 3
      • Locate the two plastic LCD unit hooks.
      • Pry hooks outward.
      Ask FixBot
    2. Nokia 2128i Logic Board Replacement: step 8, image 1 of 3 Nokia 2128i Logic Board Replacement: step 8, image 2 of 3 Nokia 2128i Logic Board Replacement: step 8, image 3 of 3
      • Gently pull LCD unit away from the logic board.
      • Be careful not to damage the connection on the top, right hand side of the logic board.
      Ask FixBot
Chad
28 Reputation
5 Guides authored
Cal Poly, Team 20-8, Maness Fall 2010 Member of Cal Poly, Team 20-8, Maness Fall 2010
CPSU-MANESS-F10S20G8
4 Members
144 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 33
All Time: 1,750
