Nokia 2128i LCD Screen Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
85
All Time:
2,052
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
When there is a crack in your screen or it just won't display, change the LCD screen out.
Tools
    1. Nokia 2128i LCD Screen Replacement, Battery: step 1, image 1 of 3 Nokia 2128i LCD Screen Replacement, Battery: step 1, image 2 of 3 Nokia 2128i LCD Screen Replacement, Battery: step 1, image 3 of 3
      • Be sure cell phone is off before you begin to disassemble the phone.
      • Press the button on the bottom of the back of the cell phone.
      • Slide rear panel down and remove it.
      Ask FixBot
    2. Nokia 2128i LCD Screen Replacement: step 2, image 1 of 3 Nokia 2128i LCD Screen Replacement: step 2, image 2 of 3 Nokia 2128i LCD Screen Replacement: step 2, image 3 of 3
      • Using your fingernail, pry the back of the battery upwards and pull out.
      Ask FixBot
    1. Nokia 2128i LCD Screen Replacement, Faceplate: step 3, image 1 of 3 Nokia 2128i LCD Screen Replacement, Faceplate: step 3, image 2 of 3 Nokia 2128i LCD Screen Replacement, Faceplate: step 3, image 3 of 3
      • Insert the plastic opening tool under the faceplate.
      • Separate the faceplate from main body by twisting the prying tool with some force.
      • The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
      Ask FixBot
    1. Nokia 2128i LCD Screen Replacement, Keypad: step 4, image 1 of 3 Nokia 2128i LCD Screen Replacement, Keypad: step 4, image 2 of 3 Nokia 2128i LCD Screen Replacement, Keypad: step 4, image 3 of 3
      • With the faceplate removed, simply peel off rubber key pad and remove.
      Ask FixBot
    1. Nokia 2128i LCD Screen Replacement, Motherboard Assembly: step 5, image 1 of 3 Nokia 2128i LCD Screen Replacement, Motherboard Assembly: step 5, image 2 of 3 Nokia 2128i LCD Screen Replacement, Motherboard Assembly: step 5, image 3 of 3
      • Locate and remove the six screws on the front of the phone using a T6 Torx.
      • All 6 screws are 6.9mm long.
      Ask FixBot
    2. Nokia 2128i LCD Screen Replacement: step 6, image 1 of 3 Nokia 2128i LCD Screen Replacement: step 6, image 2 of 3 Nokia 2128i LCD Screen Replacement: step 6, image 3 of 3
      • After removing screws, lift the motherboard assembly straight off the cell phone body.
      Ask FixBot
    1. Nokia 2128i LCD Screen Replacement, Speaker: step 7, image 1 of 3 Nokia 2128i LCD Screen Replacement, Speaker: step 7, image 2 of 3 Nokia 2128i LCD Screen Replacement, Speaker: step 7, image 3 of 3
      • With the LCD unit removed, gently press out the speaker with a non-metallic pointed object.
      Ask FixBot
    1. Nokia 2128i LCD Screen Replacement, LCD Screen: step 8, image 1 of 3 Nokia 2128i LCD Screen Replacement, LCD Screen: step 8, image 2 of 3 Nokia 2128i LCD Screen Replacement, LCD Screen: step 8, image 3 of 3
      • Pull one of the bottom corners of the rubber casing outward and detach LCD screen.
      Ask FixBot
    2. Nokia 2128i LCD Screen Replacement: step 9, image 1 of 3 Nokia 2128i LCD Screen Replacement: step 9, image 2 of 3 Nokia 2128i LCD Screen Replacement: step 9, image 3 of 3
      • Once the LCD screen is detached from a majority of the rubber casing, pry out the highlighted portion.
      Ask FixBot
    3. Nokia 2128i LCD Screen Replacement: step 10, image 1 of 2 Nokia 2128i LCD Screen Replacement: step 10, image 2 of 2
      • The highlighted portion is fragile. Pry gently when removing from rubber casing.
      Ask FixBot
Curtis Lutje
43 Reputation
6 Guides authored
Cal Poly, Team 20-8, Maness Fall 2010 Member of Cal Poly, Team 20-8, Maness Fall 2010
CPSU-MANESS-F10S20G8
4 Members
144 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 85
All Time: 2,052
