Up to 20% off select tools
Nokia 2128i Battery Replacement
Views: 1K
View statistics:
Past 24 Hours:
0
Past 7 Days:
3
Past 30 Days:
25
All Time:
1,010
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 2 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
If you are having issues with your phone's battery life or connection, change the battery.
    1. Nokia 2128i Battery Replacement, Battery: step 1, image 1 of 3 Nokia 2128i Battery Replacement, Battery: step 1, image 2 of 3 Nokia 2128i Battery Replacement, Battery: step 1, image 3 of 3
      • Be sure cell phone is off before you begin to disassemble the phone.
      • Press the button on the bottom of the back of the cell phone.
      • Slide rear panel down and remove it.
      Ask FixBot
    2. Nokia 2128i Battery Replacement: step 2, image 1 of 3 Nokia 2128i Battery Replacement: step 2, image 2 of 3 Nokia 2128i Battery Replacement: step 2, image 3 of 3
      • Using your fingernail, pry the back of the battery upwards and pull out.
      Ask FixBot
Author
with
Chad
28 Reputation
5 Guides authored
Cal Poly, Team 20-8, Maness Fall 2010 Member of Cal Poly, Team 20-8, Maness Fall 2010
CPSU-MANESS-F10S20G8
4 Members
144 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 25
All Time: 1,010
