Up to 20% off select tools
Nokia 2115i Faceplate Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
Past 7 Days:
20
Past 30 Days:
85
All Time:
2,314
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Parts
Tools
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Replacing the faceplate is very quick and simple to do.
    1. Nokia 2115i Faceplate Replacement, Nokia 2115i Battery: step 1, image 1 of 3 Nokia 2115i Faceplate Replacement, Nokia 2115i Battery: step 1, image 2 of 3 Nokia 2115i Faceplate Replacement, Nokia 2115i Battery: step 1, image 3 of 3
      • To prevent shock, press down on the power button located on the top of the phone until the phone shuts off.
      • Press down on the small gray button located on the back of the phone.
      • Slide the back plate down and off.
      Ask FixBot
    2. Nokia 2115i Faceplate Replacement: step 2, image 1 of 2 Nokia 2115i Faceplate Replacement: step 2, image 2 of 2
      • To remove the battery, begin by holding the phone sideways.
      • Then, insert your thumb in the groove below the battery and push the battery up and out.
      Ask FixBot
    1. Nokia 2115i Faceplate Replacement, Faceplate: step 3, image 1 of 3 Nokia 2115i Faceplate Replacement, Faceplate: step 3, image 2 of 3 Nokia 2115i Faceplate Replacement, Faceplate: step 3, image 3 of 3
      • Locate the spudger. A photo of the correct spudger is provided to the left.
      • Turn the front of the phone to face you. Find the two small square holes on the bottom left and right sides of the faceplate.
      • Insert the spudger into each square hole and push up to detach the face plate.
      Ask FixBot
Author
with
Shane
80 Reputation
6 Guides authored
Cal Poly, Team 14-38, Forte Fall 2010 Member of Cal Poly, Team 14-38, Forte Fall 2010
CPSU-FORTE-F10S14G38
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 85
All Time: 2,314
