Introduction
Use this guide to replace the screen in your phone.
Flip the phone over so that the screen faces down.
Press the gray button on the battery cover and slide it down off the back of the phone.
Wedge the flat end of the spudger into the small indent next to the Nokia logo on the battery.
Gently pry the battery out of the phone.
Firmly grip the back of the casing.
Separate the front and back casings either by pulling them apart from the middle or gently prying the front off with your fingers from the bottom.
Remove the six 6mm T6 Torx screws around the edge of the front of the phone.
Remove the metal frame holding the screen and speaker.
Flip over the metal frame you just removed.
Using the flat end of the spudger, pry apart the inner clear plastic frame with screen attached from the metal frame.
Remove the screen bearing plastic frame.
2 other people completed this guide.
