Nokia 1010 Speaker Replacement
    1. Nokia 1010 Speaker Replacement, Battery: step 1, image 1 of 2 Nokia 1010 Speaker Replacement, Battery: step 1, image 2 of 2
      • Using your thumbs, press and slide down the back cover of the Nokia 1010.
      Ask FixBot
    2. Nokia 1010 Speaker Replacement: step 2, image 1 of 3 Nokia 1010 Speaker Replacement: step 2, image 2 of 3 Nokia 1010 Speaker Replacement: step 2, image 3 of 3
      • Insert the prying tool in the notch above the battery.
      • Once the prying tool is inserted, lift up the battery.
      Ask FixBot
    1. Nokia 1010 Speaker Replacement, Faceplate: step 3, image 1 of 2 Nokia 1010 Speaker Replacement, Faceplate: step 3, image 2 of 2
      • Insert the prying tool between the seam of the faceplate and the body.
      Ask FixBot
    2. Nokia 1010 Speaker Replacement: step 4, image 1 of 3 Nokia 1010 Speaker Replacement: step 4, image 2 of 3 Nokia 1010 Speaker Replacement: step 4, image 3 of 3
      • Starting from the bottom of the phone, begin prying around the base of the phone alternating form left to right.
      Ask FixBot
    3. Nokia 1010 Speaker Replacement: step 5, image 1 of 3 Nokia 1010 Speaker Replacement: step 5, image 2 of 3 Nokia 1010 Speaker Replacement: step 5, image 3 of 3
      • As the base loosens, slowly increase the separation between the plates and the body of the phone.
      Ask FixBot
    1. Nokia 1010 Speaker Replacement, Motherboard: step 6, image 1 of 3 Nokia 1010 Speaker Replacement, Motherboard: step 6, image 2 of 3 Nokia 1010 Speaker Replacement, Motherboard: step 6, image 3 of 3
      • Using the spudger, pry back three tabs located on the left edge and three tabs located on the right edge of the body.
      Ask FixBot
    2. Nokia 1010 Speaker Replacement: step 7, image 1 of 3 Nokia 1010 Speaker Replacement: step 7, image 2 of 3 Nokia 1010 Speaker Replacement: step 7, image 3 of 3
      • Once detached, lift and remove the faceplate from the motherboard.
      Ask FixBot
    1. Nokia 1010 Speaker Replacement, Speaker: step 8, image 1 of 3 Nokia 1010 Speaker Replacement, Speaker: step 8, image 2 of 3 Nokia 1010 Speaker Replacement, Speaker: step 8, image 3 of 3
      Tool used on this step:
      Buy
      • Insert tweezers into the small crevices of the backside of the speaker, and lift upwards.
      Ask FixBot
8 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 47
All Time: 2,026
