Up to 20% off select tools
Nokia 1010 Screen Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
6
Past 7 Days:
26
Past 30 Days:
121
All Time:
3,297
Comments: 6
2 comments on steps, 4 guide comments.
Go to guide comments
Completed: 15
15 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Difficult
Tools
  • Spudger
    4.9
  • iFixit Opening Tool
    4.8
Introduction
Go to step 1 ↓
This guide will help you to access the screen if you have cracked it and want to replace the whole screen. Additionally this guide can help you to access the screen if your screen is not turning on to check to see if the screen is attached properly. This guide will give you step by step instructions on how to take the device apart in order to access the screen.
    1. Nokia 1010 Screen Replacement, Battery: step 1, image 1 of 2 Nokia 1010 Screen Replacement, Battery: step 1, image 2 of 2
      • Using your thumbs, press and slide down the back cover of the Nokia 1010.
      Ask FixBot
    2. Nokia 1010 Screen Replacement: step 2, image 1 of 3 Nokia 1010 Screen Replacement: step 2, image 2 of 3 Nokia 1010 Screen Replacement: step 2, image 3 of 3
      • Insert the prying tool in the notch above the battery.
      • Once the prying tool is inserted, lift up the battery.
      Ask FixBot
    1. Nokia 1010 Screen Replacement, Faceplate: step 3, image 1 of 2 Nokia 1010 Screen Replacement, Faceplate: step 3, image 2 of 2
      • Insert the prying tool between the seam of the faceplate and the body.
      Ask FixBot
    2. Nokia 1010 Screen Replacement: step 4, image 1 of 3 Nokia 1010 Screen Replacement: step 4, image 2 of 3 Nokia 1010 Screen Replacement: step 4, image 3 of 3
      • Starting from the bottom of the phone, begin prying around the base of the phone alternating form left to right.
      Ask FixBot
    3. Nokia 1010 Screen Replacement: step 5, image 1 of 3 Nokia 1010 Screen Replacement: step 5, image 2 of 3 Nokia 1010 Screen Replacement: step 5, image 3 of 3
      • As the base loosens, slowly increase the separation between the plates and the body of the phone.
      Ask FixBot
    1. Nokia 1010 Screen Replacement, Motherboard: step 6, image 1 of 3 Nokia 1010 Screen Replacement, Motherboard: step 6, image 2 of 3 Nokia 1010 Screen Replacement, Motherboard: step 6, image 3 of 3
      • Using the spudger, pry back three tabs located on the left edge and three tabs located on the right edge of the body.
      Ask FixBot
    2. Nokia 1010 Screen Replacement: step 7, image 1 of 3 Nokia 1010 Screen Replacement: step 7, image 2 of 3 Nokia 1010 Screen Replacement: step 7, image 3 of 3
      • Once detached, lift and remove the faceplate from the motherboard.
      Ask FixBot
    1. Nokia 1010 Screen Replacement, Screen: step 8, image 1 of 3 Nokia 1010 Screen Replacement, Screen: step 8, image 2 of 3 Nokia 1010 Screen Replacement, Screen: step 8, image 3 of 3
      • Locate the four clear tabs that connect the screen to the motherboard.
      Ask FixBot
    2. Nokia 1010 Screen Replacement: step 9, image 1 of 3 Nokia 1010 Screen Replacement: step 9, image 2 of 3 Nokia 1010 Screen Replacement: step 9, image 3 of 3
      • Insert the prying tool between the tabs and the motherboard. Loosen and separate slowly.
      Ask FixBot
15 other people completed this guide.
Author
with
Mikala Presho
966 Reputation
3 Guides authored
4 Guide Comments
يبقه على الشعار مال النوكيه بس
حيدر حمود - Reply Share
You didn't even removed the screen you just removed the glass.
Macro Man - Reply Share
To be very honest 😅
Eniang Innocent - Reply Share
Qada saar telephone
Zekeriye Abdi - Reply Share
Past 24 Hours: 6
Past 7 Days: 26
Past 30 Days: 121
All Time: 3,297
