Up to 20% off select tools
Nokia 1010 Battery Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
28
Past 30 Days:
142
All Time:
3,347
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 minute
Difficulty: Very easy
Tools
Introduction
Go to step 1 ↓
If you have had troubles with the battery life of your phone and want to replace the battery, this guide will help you to access the battery and help you replace the battery step by step. If your phone will not turn on at all and you would like to make sure that the battery is fully intact, this guide will show you how to access the battery.
    1. Nokia 1010 Battery Replacement, Battery: step 1, image 1 of 2 Nokia 1010 Battery Replacement, Battery: step 1, image 2 of 2
      • Using your thumbs, press and slide down the back cover of the Nokia 1010.
      Ask FixBot
    2. Nokia 1010 Battery Replacement: step 2, image 1 of 3 Nokia 1010 Battery Replacement: step 2, image 2 of 3 Nokia 1010 Battery Replacement: step 2, image 3 of 3
      • Insert the prying tool in the notch above the battery.
      • Once the prying tool is inserted, lift up the battery.
      Ask FixBot
7 other people completed this guide.
Author
with
Mikala Presho
966 Reputation
3 Guides authored
1 Guide Comment
Instead of charging the battery the phone drains the battery how can I fix it
alfred ayegba - Reply Share
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 142
All Time: 3,347
