Nokero SunRay Pro Power Panel Capacitor Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
89
All Time:
707
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Not being able to charge your device may mean you have a bad capacitor. Follow these simple steps to get yours replaced.
Tools
    1. Nokero SunRay Pro Power Panel Capacitor Replacement, Front and Back Case: step 1, image 1 of 1
      • Turn over the device so that the back of the device is facing up.
      Ask FixBot
    2. Nokero SunRay Pro Power Panel Capacitor Replacement: step 2, image 1 of 3 Nokero SunRay Pro Power Panel Capacitor Replacement: step 2, image 2 of 3 Nokero SunRay Pro Power Panel Capacitor Replacement: step 2, image 3 of 3
      • Insert the first plastic opening tool along the side to pry open the case.
      • Sliding the plastic opening tool, while inserted, along the seam may help the removal process.
      • Use a second plastic opening tool to help separate the remaining seams.
      Ask FixBot
    3. Nokero SunRay Pro Power Panel Capacitor Replacement: step 3, image 1 of 2 Nokero SunRay Pro Power Panel Capacitor Replacement: step 3, image 2 of 2
      • There is a long strip of double sided adhesive foam tape that prevents the back case from easily being removed.
      • Pull the back case off by applying steady pressure to remove it from the adhesive foam tape.
      Ask FixBot
    4. Nokero SunRay Pro Power Panel Capacitor Replacement: step 4, image 1 of 2 Nokero SunRay Pro Power Panel Capacitor Replacement: step 4, image 2 of 2
      • Use the Phillips precision screwdriver to unscrew the two 5.0 mm Phillips screws from the circuit board.
      • Remove the solar panel and circuit board from the front case.
      Ask FixBot
    1. Nokero SunRay Pro Power Panel Capacitor Replacement, Capacitor: step 5, image 1 of 1
      • Use the soldering station to desolder the two contact points around the connections of the capacitor to loosen the metal.
      Ask FixBot
    2. Nokero SunRay Pro Power Panel Capacitor Replacement: step 6, image 1 of 1
      • Pull the capacitor through the circuit board to remove it.
      Ask FixBot
Nicholas Orr
229 Reputation
2 Guides authored
USF Tampa, Team 9-3, Blackwell Winter 2015 Member of USF Tampa, Team 9-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G3
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 89
All Time: 707
