Up to 20% off select tools
Nokero N400 Switch Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
84
All Time:
828
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If pushing the power switch up to the on direction, you may need to use this guide to replace the power switch.
    1. Nokero N400 Switch Replacement, Remove Battery Cover: step 1, image 1 of 3 Nokero N400 Switch Replacement, Remove Battery Cover: step 1, image 2 of 3 Nokero N400 Switch Replacement, Remove Battery Cover: step 1, image 3 of 3
      • Press down firmly to remove the battery cover and display battery.
      • Then remove the battery.
      Ask FixBot
    2. Nokero N400 Switch Replacement, Unscrew Back Cover: step 2, image 1 of 2 Nokero N400 Switch Replacement, Unscrew Back Cover: step 2, image 2 of 2
      • Remove the 7mm Phillips #1 screw.
      Ask FixBot
    3. Nokero N400 Switch Replacement, Pry Open Back Cover: step 3, image 1 of 2 Nokero N400 Switch Replacement, Pry Open Back Cover: step 3, image 2 of 2
      • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
      • Unlatch the clips on the inside and pull device apart.
      • Some clips will break when forced open.
      Ask FixBot
    1. Nokero N400 Switch Replacement, Remove Switch From Housing: step 4, image 1 of 1
      • Using a spudger carefully pry switch from housing.
      Ask FixBot
    2. Nokero N400 Switch Replacement, Cut Old Switch Free: step 5, image 1 of 1
      • Use wire cutters to cut the two black wires attached to the old switch.
      • You must use a splicer or a soldering gun to reattach the wires of the new switch.
      • If you splice the new switch wires together in the opposite order of the old switch wires, the new switch will still work.
      Ask FixBot
Author
with
Benjamin franklin
101 Reputation
1 Guide authored
USF Tampa, Team 19-2, Blackwell Winter 2015 Member of USF Tampa, Team 19-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 84
All Time: 828
