Nokero N400 Suction Cup Replacement
  1. Nokero N400 Suction Cup Replacement, Remove Battery Cover: step 1, image 1 of 3 Nokero N400 Suction Cup Replacement, Remove Battery Cover: step 1, image 2 of 3 Nokero N400 Suction Cup Replacement, Remove Battery Cover: step 1, image 3 of 3
    • Press down firmly to remove the battery cover and display battery.
    • Then remove the battery.
    Ask FixBot
  2. Nokero N400 Suction Cup Replacement, Unscrew Back Cover: step 2, image 1 of 2 Nokero N400 Suction Cup Replacement, Unscrew Back Cover: step 2, image 2 of 2
    • Remove the 7mm Phillips #1 screw.
    Ask FixBot
  3. Nokero N400 Suction Cup Replacement, Pry Open Back Cover: step 3, image 1 of 2 Nokero N400 Suction Cup Replacement, Pry Open Back Cover: step 3, image 2 of 2
    • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
    • Unlatch the clips on the inside and pull device apart.
    • Some clips will break when forced open.
    Ask FixBot
  4. Nokero N400 Suction Cup Replacement, Begin Removal: step 4, image 1 of 2 Nokero N400 Suction Cup Replacement, Begin Removal: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, push the edges of the back end of the suction cup inward.
    Ask FixBot
  5. Nokero N400 Suction Cup Replacement, Remove Suction Cup: step 5, image 1 of 2 Nokero N400 Suction Cup Replacement, Remove Suction Cup: step 5, image 2 of 2
    • Flip the cover over and remove the suction cup by pulling at an angle.
    • Be careful not to tear the plastic housing.
    • During reassembly, make sure to press down uniformly on the suction cup for an even fit.
    Ask FixBot
Daniel Bumiller
201 Reputation
2 Guides authored
USF Tampa, Team 19-2, Blackwell Winter 2015 Member of USF Tampa, Team 19-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G2
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 9
Past 30 Days: 47
All Time: 386
