Up to 20% off select tools
Nokero N400 Solar Panel Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
87
All Time:
767
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your flashlight no longer charges its battery, it might be time to change your solar panel with this guide.
    1. Nokero N400 Solar Panel Replacement, Remove Battery Cover: step 1, image 1 of 3 Nokero N400 Solar Panel Replacement, Remove Battery Cover: step 1, image 2 of 3 Nokero N400 Solar Panel Replacement, Remove Battery Cover: step 1, image 3 of 3
      • Press down firmly to remove the battery cover and display battery.
      • Then remove the battery.
      Ask FixBot
    2. Nokero N400 Solar Panel Replacement, Unscrew Back Cover: step 2, image 1 of 2 Nokero N400 Solar Panel Replacement, Unscrew Back Cover: step 2, image 2 of 2
      • Remove the 7mm Phillips #1 screw.
      Ask FixBot
    3. Nokero N400 Solar Panel Replacement, Pry Open Back Cover: step 3, image 1 of 2 Nokero N400 Solar Panel Replacement, Pry Open Back Cover: step 3, image 2 of 2
      • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
      • Unlatch the clips on the inside and pull device apart.
      • Some clips will break when forced open.
      Ask FixBot
    1. Nokero N400 Solar Panel Replacement, Solar Panel: step 4, image 1 of 2 Nokero N400 Solar Panel Replacement, Solar Panel: step 4, image 2 of 2
      • Pull the panel away from the rest of the assembly and cut the red and black wires coming from the panel
      • Be careful not to cut the ground-wire for the motherboard, it is the same color and goes to the exact same place as the solar panel wire.
      • For reassembly you will need to either splice, or solder the wires onto the replacement.
      Ask FixBot
Author
with
Daniel Bumiller
201 Reputation
2 Guides authored
USF Tampa, Team 19-2, Blackwell Winter 2015 Member of USF Tampa, Team 19-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 87
All Time: 767
