Up to 20% off select tools
Nokero N400 LED Panel Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
21
Past 30 Days:
104
All Time:
920
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will teach you how to safely cut wires to remove the LED light panel component from the rest of the device and replace it with a new one.
    1. Nokero N400 LED Panel Replacement, Remove Battery Cover: step 1, image 1 of 3 Nokero N400 LED Panel Replacement, Remove Battery Cover: step 1, image 2 of 3 Nokero N400 LED Panel Replacement, Remove Battery Cover: step 1, image 3 of 3
      • Press down firmly to remove the battery cover and display battery.
      • Then remove the battery.
      Ask FixBot
    2. Nokero N400 LED Panel Replacement, Unscrew Back Cover: step 2, image 1 of 2 Nokero N400 LED Panel Replacement, Unscrew Back Cover: step 2, image 2 of 2
      • Remove the 7mm Phillips #1 screw.
      Ask FixBot
    3. Nokero N400 LED Panel Replacement, Pry Open Back Cover: step 3, image 1 of 2 Nokero N400 LED Panel Replacement, Pry Open Back Cover: step 3, image 2 of 2
      • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
      • Unlatch the clips on the inside and pull device apart.
      • Some clips will break when forced open.
      Ask FixBot
    1. Nokero N400 LED Panel Replacement, Removing the LED Panel: step 4, image 1 of 2 Nokero N400 LED Panel Replacement, Removing the LED Panel: step 4, image 2 of 2
      • With the back cover of the device removed, lightly pull up on the LED assembly to lift it out of its housing.
      • The LED assembly will separate into three components; the light board, outer housing, and plastic lens.
      Ask FixBot
    2. Nokero N400 LED Panel Replacement: step 5, image 1 of 1
      • Set the outer housing and plastic lens aside.
      • Take a pair of pliers and cut the red and black wires connected to the light board.
      • Make sure to cut just below the light board.
      • To install the new light board, you will need to splice or solder the wires to the new light board.
      Ask FixBot
Author
with
Kyle Burwell
173 Reputation
1 Guide authored
USF Tampa, Team 19-2, Blackwell Winter 2015 Member of USF Tampa, Team 19-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 104
All Time: 920
