Noisy Percussion Massager Repair
Views: 16K
View statistics:
Past 24 Hours:
22
Past 7 Days:
90
Past 30 Days:
347
All Time:
15,850
Comments: 9
9 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 8 minutes
Difficulty: Easy
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Community-Contributed Guide
Introduction
Go to step 1 ↓
To fix the noisy handheld muscle massager, all you need to do is tighten the loose screw that drives the massage head. This can be done using standard screwdrivers and thread lock.
Tools
    1. Noisy Percussion Massager Repair, Tools - #1 & #2 Phillips + thread locker: step 1, image 1 of 1
      • Thread lock can be found at any hardware store.
      Ask FixBot
    2. Noisy Percussion Massager Repair, Remove the rear cover: step 2, image 1 of 2 Noisy Percussion Massager Repair, Remove the rear cover: step 2, image 2 of 2
      • Twist counter-clockwise very snug. It only moves about 1/4 of an inch - the second picture shows the slide lock slots.
      Ask FixBot
    3. Noisy Percussion Massager Repair, Remove Two Screws from Housing: step 3, image 1 of 1
      • There are two rubber plugs covering the screws that you need to get out… Not hard.
      Ask FixBot
    4. Noisy Percussion Massager Repair, Open It Up: step 4, image 1 of 3 Noisy Percussion Massager Repair, Open It Up: step 4, image 2 of 3 Noisy Percussion Massager Repair, Open It Up: step 4, image 3 of 3
      • Case opens pretty easy but you can see there are two tabs toward the back of the case … if it sticks, a simple pinch might help you open it up.
      Ask FixBot
    5. Noisy Percussion Massager Repair, Remove screw - Apply Thread Lock - Re install: step 5, image 1 of 3 Noisy Percussion Massager Repair, Remove screw - Apply Thread Lock - Re install: step 5, image 2 of 3 Noisy Percussion Massager Repair, Remove screw - Apply Thread Lock - Re install: step 5, image 3 of 3
      • Insert wisdom here.
      Ask FixBot
jtalbin
313 Reputation
2 Guides authored
9 Guide Comments
Where can I buy a gasket, for the Recovery Pro massager, that is worn out? Thank you.
Emilia Cirstea - Reply Share
I have model 11mg0811 it has no screws on the sides and I it will not twist off ,when it's on it makes a lot of noise,I don't want to return it to COSTCO IS THERE SOMEWHERE I CAN TAKE IT,
Ted - Reply Share
I've not found any shops locally that take these for repair. After looking at the pictures for the model 11MG0811 it appears that access to the inner workings is similar to an electronic toothbrush that uses a pinch/lock approach which can be quite a bit tougher.
jtalbin - Reply Share
Would this work on a trigger point impact massage gun?
It's making loud noise
Dennis - Reply Share
Past 24 Hours: 22
Past 7 Days: 90
Past 30 Days: 347
All Time: 15,850
